If you mean you put in new pull chain switches, then I'm pretty sure you have the wrong switch. What is the make/model of fan. How many wires on your capacitor & which color wire goes into which slot in the pull chain? [email protected]
Make sure your fan is on high with the pull chain switch. Push the remote Hi button then pull the chain until it's on the high speed, Then DO NOT use the pull chain. Same with light , Push light button on remote then pull chain until it's on then leave the chain alone. If that doesn't do the trick then you probably need a new receiver.
mcdevito75 here, Generally, The Fan switch itself is a pull chain type switch on the fan motor itself, this is a fan speed switch, NOW! also generally the reverse fan swtich is another shorter pull chain switch just about an inch away from the Fan Speed switch or the longer pull chain switch on the fan motor. This reverse switch can also be a toggle type or slide type switch but will be close to the fan speed switch on the fan motor itself.
You need the little coupler thing that connects to the ball that makes up the chain. If you dont have the coupler ... you could get one at your local Ace Hardware store ... or you could just purchase a similar switch which would have the coupler on the chain.
