It is the play/pause button it blinks and want starthttps://www.fixya.com/ssl/askdetails.aspx#
SOURCE: Control panel lights up but washer will not run
Press "end of cycle" button to clear screen. Maybe your previous washer was here........drain pipe.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Important: height of drain hose is abt 3 feet from ground level.
Rate me pl.....if helped.
SOURCE: lg tromm wm2277hw code de
Error Code "de" is for "door switch assembly faulty".
You can down load the service manual from this site:
http://136.166.4.200/contents/Laundry/WM2277.htm
Have fun!
SOURCE: TROMM LG WM-2277HW
You may have a broken door latch switch that doesn't tell the computer that the door is actually closed. Before you actually replace the latch switch, make sure the wire connectors are securely attached to the latch assembly.
SOURCE: front load washer leak
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
SOURCE: lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
