SOURCE: How to setup scan to pc on Konica minolta bizhub 350 Error ED09C7
Your configuration sharing SMB folder is incorrect. Create desktop folder rename all upper case SMB right click on the folder and click sharing and set full control to everyone. Go to web brouser type in the ip address of the printer log on to administrator password 8 zeros or 12345678 and change the setting.
SOURCE: konica minolta bizhub 200 c2557. Help please!
c-2557= ATDC Sensor abnormality to reset go to service mode, to enter service mode perform these steps, 1-press utility/counter button from the panel, 2-press check details, and press "STOP" 0,0, STOP 0,1 3-now you are in service mode, 4-click on tech rep mode,or Adjustment 5-now click on "Printer" 6-here increase the value, suppose you have 150, make it 170, press the clear button to clear it and enter new value which should be more than the previous one. press enter and exit from the service mode.
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
SOURCE: REMEDY TO SOLVING ERRORS COF32 AND CO650 IN KONICA
to remove code "COF32" from your machine, simply change the developer with the new one.
code will remove.
wish you best of luck............
