If it doesn't have a dipstick then it is a sealed transmission and you must see the dealer. &Unless it is leaking you need not check the fluid level, it doesn't evaporate.
Maybe the little sensor or pin that sticks up and is pushed in when you close the lid is broken and the software doesn't realize the lid has been closed.
check the lid switch,open the lid,stick a screw driver into the hole where the strike on the lid closes into,you should hear a clicking sound,no click the lid switch is bad,or close the lid and open it up a few inches and close it down,no clicking sound the switch is bad.you can watch this video and it will show you how to change the switch http://www.youtube.com/watch?v=V5aW9WkTFhEif the part number is 3949247 and the lid switch is around 50 dollars,common problem.if you hear the switch click when you stick the screw driver into the hole set the timer to spin,pull out the timer knob and then stick the screw driver into the hole again,if the switch is engaging it will drain and spin but if it doesn't click change the switch.good luck,if you need anymore help let me know.
It looks like the key is the same as most modern Casio registers. It should be the same as the TK-6000 and TK-7000 so order one of those keys and try it
In most cases this means bad memory stick. If you are able to, flip over the laptop, find the panel that has the memory under it, unscrew the screw(s) to get the panel off, and pull out the top stick of memory. Flip the laptop back over and power it on. If it works fine again, then that stick was the problem, and you can go buy a replacement and install it back into that slot. If that doesn't fix the issue, turn it off, flip it over, pull the other stick of memory out and put the first stick into that slot. Flip it back upright and turn on again. If that fixes the issue, then the second stick of memory is bad and you can just replace it as well. If neither of those fix the issue please reply on here and we can do further diagnostics.
The mounting bracket is meant for mounting on the windscreen. It won't stick to the pebbled vinyl surface of the dashboard as the surface allows air in. You take off the thin clear plastic cover. The black disk that came with the satnav can be stuck to your dashboard if you want to mount the satnav there. Clean the dashboard and peel off the plastic cover off the disk to stick it to the dashboard. Be sure not to put it where there's an airbag. You can then attach the satnav to the other side of the disk the same as to the windscreen.
To attach the satnav to the windscreen press the suction mount against the screen and press the lever towards the screen. To remove it pull back the lever and lift the tab on the suction pad.
