Commpaq 110 mini goes to start windows counts down then goes back to the window xp start up does this over and over the f2 does'nt work f11 does
These WEB site may offer a solution for this problem.
Computer In Start Reboot Loop
http://pcsupport.about.com/od/findbysymptom/ht/returns-to-advanced-boot-options.htm http://windows.microsoft.com/en-us/windows/help/printer-problems-in-windows
SOURCE: windows dosent start
go n format it by using a recovery drive...there may be a start up errors occured in windows
SOURCE: start up issues
go onto the bios after pressing f2 and look through the options and tabs and tick or change whichever option is about the setup or start up
SOURCE: I have an acer aspire 5315 and on start up it goes
This can be caused by a hardware failure (e.g. hard drive, etc.) or an operating system (OS) issue. Either way I would recommend taking it to a computer repair shop so they can diagnose the issue.
If its an OS issue most likely the cheapest way to fix it will be reloading the OS on a new hard drive(because its cheaper to buy a hard drive then have a company backup your data) then plug in your old hard drive to get access to your data.
SOURCE: Windows xp will not boot on my hp mini 110.Keeps
Try selecting Last Known Good Configuration, or Safe Mode, and use System Restore option to go back to a date where the system booted correctly.
If neither of these options work, then you need to try to get into Recovery Console:
SOURCE: Hi, My Samsung R580 I3 JBB2-US
You can try go to Start - Control Panel - Power Options and check what you want computer do when you close the lid of your laptop. Fix that and restart laptop to apply the setting.
If the boot up not complete and restart by itself, in my opinon, there is something wrong on the start up process, could be hardware malfuctions, could be a software not compatible. Try check the start up process to see.(use Start- Run: msconfig)
If this happen often, you should call the Samsung customer services to find out. Laptop i3 should still under warranty.
Hope this will help.
Thanks for reading
