SOURCE: how to open case for a dell dimension 4600c computer
Here's a Diagram Snap-Shot of the first step. (just enter the verification code and view.)
That's it for opening the case!
More information (General Everything about and how-to Guide) on your Dell can be found HERE.
The Dell Guide Link is a .pdf file from Dell's Support Section.
I Hope This Helps.
SOURCE: Dell Dimension E520 has
Shutdown the system and disconnect the power cable.Disconnect external peripherials.Hold the power button for 10 secs to drain static power.connect the power cable to the computer.turn on the computer and hit the F2 key to boot in bios.If you are in the bios turn on the caps lock,scroll lock, and numlock key.then Hold the Alt key + E, then Alt key + F, Alt key + B. Computer will restart check for hdd or boot device.If hdd is detected it should boot to desktop.If issue persist .Shut down the system.disconnect power cable.Hold power button for 10 secs.Open the tower and disconnect the hdd from the sata or ide cable.Connect hdd in a different sata or ide connector.Connect power cable and turn on the computer and follow steps 1.If still getting same error possible hdd gone bad.Good Luck.
SOURCE: IDE Device Failed on Dell Dimension
Hi
Thank you for your query
From the error message that you are seeing you are having a issue with one or both of your IDE devices. These devices are your Hard drive or/and your CD/DVD drive
I would not recommned that you tackle it yourself if you have no PC engineering experience
Please book into a reputabe firm for further diagnosis, it may be that you may need to discoonect the IDE drive from the devices and give it a clean or alternativley one of the devices may be faulty
If this has been useful please leave positive feedback/vote/testimonial as
this will help me greatly - Thank you again
SOURCE: How do you open the case on a Dell Dimension 3000
http://support.dell.com/support/edocs/SYSTEMS/dim3000/en/SM/cvrop.htm#wp1076111
will show you how to remove the side panel.
and here is the rest of the Dell Dimension 3000 manual for info on replacing computer parts.
http://support.dell.com/support/edocs/SYSTEMS/dim3000/en/SM/index.htm
SOURCE: How do I open a Dell Dimension B110 Case?
If you look on the top near the back there is a black oval looking button...you have to press that down...ALSO you have to press the same button on the bottom of the machine. It opens like a wallet but you have to press those oval buttons to release the latch.
