SOURCE: Printer Problems-Hp Deskjet F380
It isn't really 'printing' a white line but rather NOT printing at all. These are generally called 'voids' in the copier trade.
About the only thing that can cause this is the momentary loss of contact of a 'common' electrical pathway.
Removing the the cartridge, you will find a pattern of contacts, normally on the back of the cartridge.
Try using a cotton swab moistened (not dripping) with rubbing alcohol to scrub the contacts and reinstall after it is dry again. You can safely wipe any remaining moisture away with another swab.
If the loss of contact is caused by any contaminents, this is enough to remove them.
Avoid touching the nozzle area to prevent other problems.
This may not apply to you but this kind of problem can be caused by tobacco smoke which produces a sticky film often causing electrical problems in paths handling low currents.
SOURCE: TIMES PRINTER DOES NOT PRINT ,& OTHER TIMES ,IT IS BEAUTIFULL
you do not clean the heads on a HP printer the heads are on the print cartridge. You can run a 'cleaning cycle' if you have noticed your prints loosing some quality.
SOURCE: How do I clean the printer head for a HP deskjet 6540?
Have a look at the manual for this printer:
http://h10032.www1.hp.com/ctg/Manual/c00251861.pdf
Section 8.5 and 8.6 describes very detailed how to clean the cartridges automatically and manually.
If you have, use latex gloves, so you don't have that mess of ink on your fingers.
Enjoy!
SOURCE: hp deskjet 5552 printer Problem: cartridge
Here is a page explaining how to resolve this issue:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=71895&prodTypeId=18972&prodSeriesId=71895&objectID=c00681585
SOURCE: HP Deskjet D2360. How can I clean the printer
take out the ink and on a soft cloth wipe the printhead down 3 times then do a cleaning on the machine
