My Samsung Silver Nano Health system AC in not coming on. There is a beep when the power switch is put on. The remote is also missing. Whatc ould be wrong and how can it be resolved?
Check the remote control: Look for a button on your remote control labeled "Beep" or "Sound". Press this button to turn the beep sound back on .
Check the settings: If you can't find a "Beep" or "Sound" button on your remote control, check the settings menu on your AC unit. Look for an option to turn the beep sound on or off and make sure it's turned on .
Reset the AC unit: If neither of these steps work, try resetting your AC unit to its factory default settings. To do this, turn off the AC unit and unplug it from the power outlet. Wait for a few minutes and then plug it back in and turn it on .
If none of these steps work, it's best to contact a professional or LG's service center for further assistance.
I hope this helps!
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me and I thank him even today
There is an on/off switch on the bottom of the helicopter right next to the port where you plug the charger in, It's easy to miss, but if you look closely you'll find it.
it's not the cap's fault that i see as the real problem,the cap is used to start the compressor and is rated for so many starts per hour and if you go over this rating it will stress the cap and after some time it will fail and this problem is known as short cycling and is normally caused by your thermostat.Or the unit is starting up under large gas pressure loads due to air in the system and or moisture and can only be fixed by a new gas charge
