Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
GS6SHEXN500 fridge light and display on temp control flickers and sounds like relay making noise
Noise stops when depress door switch rest of fridge seems ok
Posted by dwight on
John Tripp
  • Whirlpool Master
  • 4,656 Answers
The problem could be very well a relay that has the contacts pitted or weak causing the lighting in display and the interior lights to flicker. Here is a GS6SHEXNS00 Parts List and the relays I can see are in a covered control box near the compressor on page 17 and 18 on the parts list 2304056 Electronic Control I will be here if you should have any questions, Thanks Sea Breeze
Posted on Apr 02, 2013
5 Related Answers
Anonymous
  • 66 Answers
SOURCE: whirlpool GD5RHAXNQ SIDE BY SIDE, CHIRPING NOISE WHEN LIGHT IS PLUGGED IN
short in the control panel. or the ground in the control panel is loose.
Posted on Dec 26, 2007
Anonymous
SOURCE: Whirlpool Gs5shaxnb02 Ice maker
HI!
In my refrigrator ice is not making . My frig is about one year old side by side. All of a sudden I noticed water stop coming in the ice dispenser. Please advise me what went wrong.
Thanks
Posted on Aug 18, 2008
Anonymous
  • 750 Answers
SOURCE: Fridge freezer intermittently not switch
Hello Patdorrian,
Welcome.
0 Degrees is okay!
How long has the compressor been off when you need to switch it off and on to make it start again?
Perhaps it was on when you were out of the room for a short period?
Is it in a room that you spend hours in to be sure that this is the situation!
Do you have a thermometer in the freezer?
What is the model #.
And how old is the unit?
Waiting your response.
Bless You Huuum
Please remember to leave a rating after you finish.
Posted on Sep 22, 2008
Anonymous
  • 242 Answers
SOURCE: panel between fridge and freezer very hot and no sound at all
Dont know about the noise prob. but I can help with the over heating cabinet. Your condensing coil is dirty and needs cleaned. it is located under your refrigerator or behind the back panel. You should use a brush and vac. it out. Air must travel through the tubing freely in order to cool properly. It should be easy to find following the tubes coming out of your compressor.
Posted on Dec 30, 2008
jessie batacan
  • 59 Answers
SOURCE: whirlpool gold refridgerator light not working and is making funny noise
switch of your refrigerator then try replacing the light that doesn't work then try to switch it back on. the light might be the cause of the noise. it might be grounded. replacing the light might reduce the noise then observed the noise for a week then if it still making noise that's the time for you to get a technician that could fix your refrigerator.hope it helped... send us a message for more concerns thank you...
Posted on Jun 03, 2009
I have a Servis fridge freezer and it's making a clicking noise at the front at the top. Fridge and freezer working but noise annoying . Stops when u open the door. What is causing this.
Does it have a fan? If so fan may activate when the door switch closes. Open the door and hold switch then and check for noise.
Jan 20, 2016 | Refrigerators
My whirlpool sixth sense fridge freezer is reading F01% (fridge side) the motor seems to be overworking(making noise) but doesn't;t do so when fridge door is open. The freezer seems to be fine and...
the motor is suppose to stop when the door opens and turns on when closing the noise could be ice building up and the fun blade rubbing the ice if unit is empty you should leave the unit disconnected so ice melts and noise will go away when reconnecting if no motor replacement is needed.
Dec 26, 2014 | Whirlpool Refrigerators
I have a samsung fridge freezer model no RSH1DTMH and the fridge will not go lower than 13degrees and the freezer and water dispenser seem ok. The fridge freezer is only 3 years old. Any ideas/
We had the same fault on our Samsung American style RSH1DBRS fridge freezer as lots of other people seem to be having. After doing lots of research, we found the best solution seemed to be to buy a repair kit from Appliance DIY Repairs. The instructions were fantastic and the installation was a doddle. Excellent service & well priced.
Jan 19, 2011 | Samsung RS2630SH Side by Side Refrigerator
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This...
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This fan would switch off when the door was opened
Sep 14, 2010 | Samsung Refrigerators
Jenn Air fridge water dispensor stopped working
Hi: You press the switch and it makes a faint humming noise. That tells me the switch on the front panel is ok. The switch for the ice and water is actually on the bottom of the ref. The internal system of the ref is not under city water pressure. Ice is made so that's ok. There is a solenoid where the water attaches to the fridge down below which can fail. Just for giggles try tapping the switch with the plastic handle of a screwdriver. To loosen any scale that might have built up. As I'm unemployed also I'm giving you that trick. Otherwise I would just say replace it. I hope this helps, Jeff
Jun 09, 2009 | Jenn-Air JBR2088HES Stainless Steel Bottom...
Ice build up in bottom of refridgerator, loud fan noise
check gaskets for air leaks or blocked drain in freezer section
Jun 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Noise from fridge when doors are closed.
There is a good chance this is the culprit.
Servicing the Evaporator Fan
In some cases, a faulty thermostat may not be the cause of a warm refrigerator or freezer. A warm box may also be caused by a defective fan, a blocked fan, or broken or bent fan blades. If the blades are jammed, try to free them. If they're bent, straighten them with pliers. If this doesn't solve the problem, call a professional service person.
On some refrigerators, the door switch operates the evaporator fan. If the fan seems to be malfunctioning, the door switch could be faulty. Test the switch as detailed in the last page, and replace it if necessary.
Good Luck! Buddy777
May 09, 2009 | LG LRFC25750 Refrigerator French Door
Fridge/freezer beeping
There is a lever switch usually above the door (when door is in open position) on the fridge cabinet. Not on the actual door. The beeping should stop if this lever is pressed. If the door is positioned correctly it would depress this lever when closed. It may be that the door adjustment is slightly out. If the beeping does not stop when depressed, then your printed circuit board (located usually above the door) is faulty and needs to be replaced.
Mar 04, 2009 | Refrigerators
Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Water does not dispense from the door but there is water to the filter fitting
connect the water line in to the solenoid [with out the filter] to see if u dispensing water
Dec 01, 2007 | GE Monogram ZISx420DR 42-inch Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
169 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
