Fisher and Paykel DishDrawer DS605FDSM Stainless Steel 23 in Builtin Dishwasher Logo
Question about Fisher and Paykel DishDrawer DS605FDSM Stainless Steel 23 in Builtin Dishwasher
Turn lock mode off
Sam
  • Fisher and P... Master
  • 3,247 Answers
Refer to page 6 (key lock) in this manual.
Posted on Apr 08, 2013
1helpful
How do I reset anti theft in my 2002 ford f150
tis a process so here goes..... Central Security Module (CSM) enable/disable mode allows autolock feature to be turned on or off. To enter enable/disable mode, close all doors. Ensure ignition switch is in LOCK position. Perform the following steps within 30 seconds:
Turn ignition switch from LOCK to RUN position.
Press power door lock switch UNLOCK button 3 times.
Turn ignition switch from RUN to OFF position.
CSM module should chirp horn indicating CSM module is in enable/disable mode and ready to accept program changes.
Press power door lock switch UNLOCK button once to command CSM module to toggle autolock feature on or off. Press power door lock switch LOCK button once to enable/disable autolock feature. CSM module will chirp one time to indicate autolock has been disabled.
CSM module will chirp once, followed by a longer chirp to indicate autolock feature has been enabled. Press power door lock switch UNLOCK button once, then turn ignition switch to OFF position to exit enable/disable mode. CSM module should chirp once to verify a feature change. Best to you.
1helpful
I can not access Sp mode in ricoh mp 4000b. How can I enter Sp mode?
Service Mode Lock/Unlock
At locations where the machine contains sensitive data, the customer engineer cannot
operate the machine until the Administrator turns the service mode lock off. This function
makes sure that work on the machine is always done with the permission of the
Administrator.
1. If you cannot go into the SP mode, ask the Administrator to log in with the User Tool
and then set "Service Mode Lock" to OFF. After he or she logs in:
[User Tools] > System Settings > Administrator Tools > Service Mode Lock >
OFF
This unlocks the machine and lets you get access to all the SP codes.
The service technician can do servicing on the machine and turn the machine off
and on. It is not necessary to ask the Administrator to log in again each time the
machine is turned on.
2. If you must use the printer bit switches, go into the SP mode and set SP5169 to "1".
3. After machine servicing is completed:
Change SP5169 from "1" to "0".
Turn the machine off and on.
Tell the administrator that you completed servicing the machine.
The administrator will then set the "Service Mode Lock" to ON.
I can't unlock my vteck 15300 dect6.0 cordless pH handset help
I guess you mean the Keypad Lock/Unlock!
You can turn on the keypad lock of a handset.
In idle mode, press * button and then LOCK to turn on the keypad lock. "PRESS UNLOCK TO USE KEYS" is displayed on the LCD.
In keypad lock mode, press UNLOCK to turn off the keypad lock.
How do you reset the alarm system on a 98 olds silhouette after it triggers without the remote entry
Theft Deterrent Arm/Disarm Modes
Important: Although mode 2 provides increased security, the content theft deterrent system disarms only by pressing unlock on the keyless entry transmitter. This can pose a problem if the keyless entry transmitter is damaged, lost, or inoperative for any reason while you attempt to disarm the content theft deterrent system.
Mode 1: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter. The system does not arm when you lock the doors with a power door lock switch.
Mode 2: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the doors with the keyless entry transmitter. The system does not disarm when you unlock the doors with the key.
Mode 3: The system arms when you lock the doors using a power door lock switch or the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter.
Changing the Feature Customization Modes
  1. Turn off the IP dimmer switch.
  2. Turn the ignition switch to the LOCK position.
  3. Remove the BCM PRGRM fuse.
  4. Turn the ignition switch to the ACC position. The BCM flashes the fasten belts indicator and sounds the chime 4 times, which indicates that BCM type 4 is installed on the vehicle. At this point, the BCM has entered the feature customization mode.
  5. In order to change the theft deterrent/shock sensor mode, turn the headlamp switch from OFF to PARK and back to OFF.
  6. The BCM flashes the fasten belts indicator and sounds the chime a number of times equivalent to the theft deterrent/shock sensor mode. A transition past mode 4 repeats the sequence starting with mode 1.
  7. Complete the following steps in order to change the theft deterrent arm/disarm mode:
6.1.
Insert the key in the left front, right front, or liftgate door lock cylinder.
6.2.
Rotate the key from the center to the unlock position.
6.3.
Press the horn button on the remote keyless entry transmitter.
6.4.
Count the number of chimes that you hear. The number of chimes tells you which mode you have set.
6.5.
Press the horn button again in order to change the mode. Continue to press the button until you hear the number of chimes that indicates the mode that you want.
6.6.
Turn the key back to the center position and remove the key from the door key cylinder.
In order to exit and save the current feature customization modes use the following procedure:
  1. Turn the ignition switch to the LOCK position.
  2. Reinstall the BCM PRGRM fuse.
If you are unable to change locking modes Theft Deterrent System Feature Customization Inoperative
How to disable ipod
Your iPod touch shows a lock symbol on the top of the screen when it's in lock mode. This protects your iPod from being accidentally bumped on or off while you're focused on other things. Getting in and out of lock mode is somewhat intuitive, but can take a couple of tries the first time.
What Does Lock Mode Do? Lock mode keeps you from accidentally turning your iPod on or off.
This helps save battery life if you have it locked while it's asleep.
It prevents your music from turning off if you've put your iPod in your pocket. However.
it's not an advanced security feature -- anyone can bring your iPod out of lock mode if they know how.
Lock Symbol When you see the lock symbol on the top of your iPod touch's screen, it always means that the iPod is in lock mode. There's no other reason for that symbol to appear. If it appears and your iPod is not in lock mode, just turn your iPod touch off and then on again and it should disappear. b> Entering Lock Mode b> Press the Sleep/Wake button on the top right of the iPod touch. You may need to hold it down for a couple of seconds. Don't hold it down for too long, as ten seconds or so will force a restart and turn your iPod completely off and then on again. b> Exiting Lock Mode b> Press the Sleep/Wake button again, and wait a moment for the screen to light up. You'll see a slider bar that prompts you to slide it to wake up and unlock the iPod touch. Put a finger or thumb on the solid part of the slider, then slide your finger to the right. This gesture is simple, but might take a couple of tries. You need to tap firmly on the slider, then keep contact with the iPod as you slide to the right.
It has a locked in the screen
What Does Lock Mode Do? Lock mode keeps you from accidentally turning your iPod on or off. This helps save battery life if you have it locked while it's asleep. It prevents your music from turning off if you've put your iPod in your pocket. However. it's not an advanced security feature -- anyone can bring your iPod out of lock mode if they know how.
Lock Symbol When you see the lock symbol on the top of your iPod touch's screen, it always means that the iPod is in lock mode. There's no other reason for that symbol to appear. If it appears and your iPod is not in lock mode, just turn your iPod touch off and then on again and it should disappear. b> Entering Lock Mode b> Press the Sleep/Wake button on the top right of the iPod touch. You may need to hold it down for a couple of seconds. Don't hold it down for too long, as ten seconds or so will force a restart and turn your iPod completely off and then on again. b> Exiting Lock Mode b> Press the Sleep/Wake button again, and wait a moment for the screen to light up. You'll see a slider bar that prompts you to slide it to wake up and unlock the iPod touch. Put a finger or thumb on the solid part of the slider, then slide your finger to the right. This gesture is simple, but might take a couple of tries. You need to tap firmly on the slider, then keep contact with the iPod as you slide to the right. Hope this helps.
b>
9helpful
My Jabra SP700 Won't turn on
You've probably set it to locked mode whitout knowing it. Here's what the manual says about that locking mode, and how to get out it:
Locking mode
To prevent accidental key presses that could turn your speakerphone
on e.g. while carrying it in a bag, the speakerphone can be
turned into locking mode. Press simultaneously the Answer/End
button and FM button for 4 seconds while the speakerphone is
turned on. The speakerphone is now turned off and can only be
turned on again by pressing Answer/End button and FM button
simultaneously for 2 seconds.
1helpful
I am not able to use the hand held lock/unlock now. The driver door lock tries to work, but it won't. If I push the lock down manually, it will lock all locks. What could be wrong?
Note:
Entering the programming mode cancels all learned keyless remotes, so none of the
previously programmed remotes will work. You must reprogram all of the keyless
remotes once you are in the programming mode. You must complete each step within 5 seconds of the previous step to keep the
system from exiting the programming mode.
1. Turn ignition switch to ON (II)
2. Press the LOCK or UNOCK button on one of the remotes. (An unprogrammed
remote can be used for this step.)
3. Turn ignition switch to LOCK (0)
4. Repeat steps 1, 2 and 3 two more times using the same keyless remote used
in step 2
5. Turn the ignition switch to ON (II)
6. Press the LOCK or UNLOCK button the same remote. Make sure the power door
locks cycle to confirm you are in programming mode.
7. Press the LOCK or UNLOCK button on each remote you want to program. Make
sure door locks cycle after you push each remote button to confirm system has
accepted the remote.
8. Turn the igniton switch to LOCK (0) to exit programming mode.
9. Test remote(s)
TURN OFF LOCK. I AM IN MENU MODE, BUT WHERE IS THE ON/OFF BUTTON LOCATED?
Power on…Turn the POWER switch ON.
If the POWER switch on the backside of this recorder is
turned OFF, it is not possible to use any of the functions.
Turn the POWER switch ON before operation.
Power off…Turn the POWER switch OFF.
Standby Mode and Display Shut Off
If the recorder is stopped for 5 minutes or longer during recording or playing, it goes into
Standby (power-save) mode, and the display shuts off. To exit Standby mode and turn on
the display, press any button.
Locking a file keeps important data from being accidentally erased.
Locked files are not erased when you choose to erase all files from a folder.
In Menu mode selection... On, OFF
On: Locks the file and prevents it from being erased.
OFF: Unlocks the file and allows it to be erased.
The battery in my 2006 pontiac vibe went dead. I recharged it; however, the setting for the door locks changed. It now unlocks automatically when I turn the car off instead of when I put the car in park. I...
The 2006 Vibe no longer has that feature. It was discontinued after 2005. I have the 2005 so I know how to change it. If your 2006 is able to change then here are the directions from my 2005.
Programmable Automatic
Door Locks
If you have an automatic transaxle, your vehicle is equipped with an auto door lock/unlock feature which enables you to program your power door locks.
Your vehicle left the factory programmed to Mode 4.
The following is a list of the available programming options:
Mode 1: All doors and liftgate lock when the shift lever is moved out of PARK (P) with the ignition on and all doors and liftgate closed. There is no automatic door unlocking.
Mode 2: No automatic door locking or unlocking.
Mode 3: All doors and liftgate lock when the shift lever is moved out of PARK (P) with the ignition on and all doors and liftgate closed. All doors and liftgate unlock when the shift lever is moved to PARK (P) with the ignition on.
Mode 4: All doors and liftgate lock when the shift lever is moved out of PARK (P) with the ignition on and all doors and liftgate closed. All doors and liftgate unlock when the ignition switch is turned from ON to ACC or to LOCK.
To change the mode you are in, do the following:
1. Set the interior lamp control dial to the door position.
See Interior Lamps Control on page 3-16.
2. Move the shift lever into PARK (P) and close all doors and liftgate.
3. Turn the ignition to ON.
4. Within five seconds after the ignition is turned to ON, press and hold the power door lock switch in
the lock position for about five seconds.
5. The interior lamp will flash to indicate that the mode has been changed. For example, if the lamp flashes once, the function has been changed to Mode 1.
If the battery is disconnected or run down, the mode is changed to the initial mode which is Mode 4.
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Marvin
Marvin
Paul Bade
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
