Kenmore 24622 Top Load Washer Logo
Question about Kenmore 24622 Top Load Washer
GE Profile WPGT9150HWW
I need to remove the agitator
Posted by kcrawfordjon on
1helpful
Ge profile wpre6150 repairs
Remove the top cap on the agitator and re-tighten the nut.
2answers
Coin stuck in agitator. how is agitator removed
Normally you can take the top of the agitator off with the use of a screw driver or by turning couter clockwise. Once the top is off you should see a nut or bolt. Removing this will allow the agitator to be removed.
Need to know how to remove agitator
To remove the agitator on a GE washer you reach down in and just pull it up to get it off. Sometimes they are stuck a little so it is hard to get to move. I hope this helps.
1helpful
Washer does not agitate. Will spin and drain.
bad dogs pull off center cap remove bolt carefully lift off dogs are two pieces that catch to agitate they are minimal cost and are easy to replace they wear out especially with heavy loads!!!Best of Luck to You!!
1helpful
My ge profile washing machine does not agitate. i need to know how to take the agitator off so i can see the coupling
remove agitator cap. if you cannot see a bolt. Ge uses a bell coupler....just pull up with all your might and it comes off. CAUTION: I've hit myself in the face, it hurts....be careful
10helpful
2answers
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
AGITATOR REMOVAL GE WASH MACHINE, MODEL WPSR3100
If you remove the top cover to the agitator, inside you will see a I believe 9/16" nut.  Remove this to take the agitator off the shaft.
vince
Marvin
Marvin
