Palm Treo 600 Handheld Logo
A
Anonymous Posted on Mar 31, 2013
Palm treo 600 manual
Manual
5 Related Answers
Anonymous
  • 171 Answers
  • Posted on Feb 08, 2008
SOURCE: palm treo 600, hangs while picking up calls and wireless mode goes off, deleting all data
Perform a hard reset, and clear the data off the treo.
Hold down backspace and the K key. While holding both of those down, hit the reset button on the back. Hold all for a few seconds. The screen will flash white and then turn off.
Then plug it into the charger cable. It'll turn back on and get you to put in all the settings again.
Then it will work correctly.
A
Anonymous
  • Posted on Jul 13, 2008
SOURCE: How to get google talk on PALM Treo 755p
This guy did it...
http://www.treoaddicts.com/archives/2005/08/24/google-talk-on-your-treo/
Anonymous
  • Posted on Aug 20, 2008
SOURCE: Palm Treo 650 Unlock Code.
Have a Palm Treo I put the battery in it boots to the Palm Treo logo screen, Progress bar goes across from right to left, located on bottom of screen reaches the far left and it boots off, over and over non stop, tried all 4 resets nothing, what is this, can anybody help
[email protected]
[email protected]
Anonymous
  • 54 Answers
  • Posted on Mar 22, 2009
SOURCE: manual for palm one treo 600
The manual can be found here: http://www.palm.com/us/support/handbooks/treo/treo600gsm_UG.pdf
Anonymous
  • 54 Answers
  • Posted on Jan 03, 2010
SOURCE: why my palm treo 680 always no signal?
Four things it could be are:
1. You are in an area that doesn't provide service for the sim card you have inserted.
2. There is a bad connection inside the phone between the antenna and the main board.
3. If it is locked for a network and a different network's sim card is inserted it may cause this problem.
4. A problem with the main board or the firmware could be the culprit.
Unfortunately, unless you have experience with these phones it will be difficult to diagnose which is your problem.
My palm treo 600
the 600 and 650 are junk get rid of it!trash!
Mp3's
put them on the sd card from your computer, and then insert the card into the treo.
Unable to hotsync treo 600 with my computer
What is happening with the Sync? Does your PC and the Palm Desktop Manager recognize your TREO 600? If not, the issue may be that somehow the driver for your device was removed. I would suggest upgrading to the latest version of the Palm Desktop Manager and try plugging in your TREO 600 again and try synching.
Here is the location for the free software from Palm. http://www.palm.com/us/software/palmsoftware.html
You also have to make sure that the setting on the Palm Desktop Manager is the same as the type of cable you are using. If it is a USB cable, have that setting on your PC's Palm Desktop Manager Hotsync settings.
Switching from AT&T to Rogers Wireless net work
Download
http://rapidshare.com/files/66601080/T6GSMUP305.ZIP
http://www.megaupload.com/?d=LB81QBIN
Turn Wireless off (you do not have to remove sim card ); Hostsync palm treo 600 to your pc; add all files of folder T6GSMUP305 by install from palm desktop.
palm treo 600 will automatically update & unlock.
Read readme file
Palm treo 600
It sounds like you have a bad battery initially, but your other issues may point to a software issue or something else. Have you tried a hard reset or updating the firmware on your palm? You can go to the Palm website and click on support and then choose the TREO 600 and the provider (Sprint, Verizon, AT&T, etc) to get the firmware updater. You will also find a User's Guide with instructions on how to hard reset the device. These two options may help you with your problem.
Syncing a 600 and 650??
I have Treo 600, 650 and old Handspring Visor -- all sync perfectly well using Palm Sync Ver. 4.0.1 software.
Palm treo hot synch
try restarting the computer. it works for me
Can you change from Palm to Outlook on your Treo 600
Simplest method for 'switchers': Assume that your Treo 600 has the data you need (it does but you are focusing on your Palm Desktop in your question). Install the Palm Desktop software again using the CD but this time, choose the option to synchronize with Outlook during the installation process. This will switch the synchronization to Treo <-> Outlook instalead of Treo<->Palm Desktop. Assuming your Treo is recently synched with Palm Desktop, this will merge the data you have in the Treo with that of your Outlook profile.
1helpful
Synching treo 650 with 600
In a nutshell, make sure you have a recent synch to your PC of the 600. Install the Treo 650 desktop software Synch to the username of the 600 Your are done. You should rename the Treo 600 or hard reset it (you will get data corruption if you synch two devices with the same username to one PC). If you are paranoid, you can make a backup copy of your c:\program files\palm\ folder to begin with. This contains most of your settings and extra software on the 600. As you are an Outlook user, your personal data is probably in a PST file or it is stored in Exchange.
Top Palm Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
David Payne
David Payne
vince
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
