Question about Canon PIXMA iP3000 InkJet Photo Printer
Why cannon ip3000 can't print in only black and white although I choose grey scale priting?
Posted by pauline_pang on
Tom Cleland
    New Friend:
  • 21 Answers
Not sure of the QUESTION..? Do you want to print colour or black and
white..? Anyway,try this, bring up image , at top left click on Fix , at top
right click on Auto Adjust then go down to Adjust Colour click on and
hold Saturation Slider move to left to remove colour ,right to add colour
go to print and it should give you a black / white image. Remember to
return image back to original colour or image will return to file in b/w
hope this works for you..goodluck...T.C.
Posted on Mar 31, 2013
5 Related Answers
pankaj_dic
pankaj rautela
  • 1252 Answers
SOURCE: pink prints where grey should be
have you clean the cartridge
Posted on Oct 21, 2008
puertobori
  • 7733 Answers
SOURCE: My printer Cannon MX280 cannot printed pictoure
Canon U.S.A. : Support & Drivers : Consumer & Home Office
Posted on Oct 27, 2010
nascentcreed1
  • 104 Answers
SOURCE: so I refilled the black
You have to refill both.
Posted on May 16, 2011
sayurisan20
  • 111 Answers
SOURCE: Canon Pixma 3600 I want black
The Grayscale print option optimizes the look of color slides for printing on a black and white printer by adding shading. The Pure Black and White option prints your slides in monochrome.
  1. Open the presentation you want to print.
  2. Click on the word File in the Menu Bar.
  3. Select the option Print.
  4. The Print dialog will appear.
example:
sayurisan20_3.jpg 5.In the Color/Grayscale section, choose the Grayscale option to print in black, white, and shades of gray. 6.Choose the Pure Black and White option to print in black and white only. 7.Click on the OK button.
Posted on Jun 06, 2011
Azrael SRL
  • 11800 Answers
SOURCE: how can i print black
Yes, there is: in Printing Preferences , in the first tab, you have the Grayscale option - select it.
Posted on Jul 29, 2011
Testimonial: "love you"
Getting light print on b&w, changing density makes zero change. Toner changed, no effect.
Check whether you are running as Black and White or Gray Scale. Many printers only print straight black by using all four toner cartridges- Cyan, Magenta, Yellow, black. If are running colored print in black and white and u choose grey scale it will automatically give you a screened image as a light print.
Mar 27, 2015 | Office Equipment & Supplies
I want to print only using black and grey ink is this posable on the cannon MG5220 printer?
I don't know this specific model but on most print drivers there is a grey scale option undr color management.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_45d8d6c78cd9f0b6
Sep 21, 2014 | Cannon Office Equipment & Supplies
My colored cartidge is out and my black is full. I went in under maintenance and changed it to balck only and printer preferences and changed it to grey scale. it still wont print black only
Some printers simply will not work if one of the cartridges is empty, even if you are not printing with the cartridge. The other catch might be is that some printers create grey scale by mixing colors so you might want to turn off grey scale and try printing just black and white.
Apr 13, 2011 | Computers & Internet
Sx515w Epson- Sounds silly but how do you print out pictures from your computer in black and white? i have tried everything and it doesnt work it still comes out in colour even though its my daughters...
It will be your printer settings, although different, yours should be similar:-
Start - Printers and faxes - RMB default printer and select properties - Advanced - Defaults - Main - Check the Grey Scale box.
You may want to upgrade the print quality aswell if printing a photo.
Apr 29, 2010 | Epson Office Equipment & Supplies
Why my color catdrige is empty faster than black
just change your settings to print in only black and white and it will print just fine. there should be a button on the top of your printer that says print black and white or grey scale , its a common problem .,if you see next time it should work good .(its actually making the black color using the colored catridge by mixing the three colors in diffent ratio.)
Mar 28, 2010 | Brother DCP 130C All-In-One InkJet Printer
My machine has ceased to print in color, only black and white, and i can't find anything on the menu that allows me to switch back to color. the cartridges are relatively new.
You do that via the Properties menu, go to printers Icon right click Icon and select "Properties" then look through to find, Color, Black & White & Grey Scale.
Feb 09, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Can I print in just black and white?
yes - in control panel - printer - properties set default as grey or grey scale or Add Printer and set the 'new' printer up as grey scale and call it 'printer B&W' so you can choose either a colour printer or a B&W printer.
Jan 17, 2010 | HP Photosmart D7160 InkJet Printer
Dell 3110cn won't print color. It shows in color on the print preview window, but comes out black & white
There's a setting in the driver that makes it print black (OK - grey scale) only.
Try that.
Jul 10, 2009 | Dell 3110cn Laser Printer
How do you chose to print black & white on a Cannon Pixma iP 1600?
You will have to get into the printer properties box when giving the print command, and select "Print in Grey Scale"
To get to Print properties, click on File > Print > In the box that pops up, select Properties. Now you should have an entry that says "Print in Gray Scale" or something like that. Select this and click OK.
Oct 20, 2008 | Office Equipment & Supplies
Canon PIXMA iP3000 InkJet Photo Printer Logo
129 people viewed this question
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
