SOURCE: toshiba laptop won't turn on
Several things could cause this problem. Be sure the battery is charged for one. For two, it could be the power supply. If it is the power supply, you will need to bring it into a shop. If it makes any sound or has any light on, the power supply may not be the problem. Good Luck!
SOURCE: hp dv6000 black screen problem
tipical hp problem, if no warranty buy a new laptop "not hp", its called "the good old fashion hp graphic chip burned"
SOURCE: Acer 5810t laptop. screen gone black
Press and hold the Power button for 45 seconds to turn the laptop off.
Then, remove the battery from the battery compartment and clean the metal contacts.
Next, reinsert the Battery and try to turn it ON.
If the display still doesn't come then you may try connecting an external display to check if the Computer is able to produce display and the issue is with the backlight of the LCD screen.
wish u good luck!!!!!!!!!!!
Testimonial: "Thanks pressing power button in for a while worked."
SOURCE: laptop fell off of bed and will not boot up no
If the system is under warranty and has complete care (Accidental Damage) coverage then you can contact Dell at 800-624-96-896 (USA) and get the system sent to the depot for repair.
If the system is not under warranty, then you need to make a decision on how much resurrecting this system if worth.
At a minimum, you are likely looking at a motherboard replacement ($150 or so parts, about as much for labor) if more than the motherboard is damaged, then it may well be cheaper to replace the system then to fix it (If the LCD is cracked it is at least another $100, if the hard drive is damaged another $50 to $100 and additional labor charges)
SOURCE: hi. My acer aspire 5735 doesnt turn on. I turned
When a computer does not boot up, but the battery is charging, it could be a CPU or RAM problem.
Re-seat the RAM modules, this will make sure it makes proper connection to the motherboard.
Next try removing the battery and power up the laptop with just the power adapter connected. If it boots up then insert the battery while it is powered up.
