SOURCE: Furuno GP31 - PC wiring instructions
try
http://furuno.inforce.dk/graphics/14_Softwares/09_gps/FURUNO_GP-32_pc_connect.pdf
SOURCE: can we connct furuno gp31 to pc
Hello!
Yes, the GP31 can connect to a PC. With the wiring harness, it has an RS-232 port, which allows it to connect to most PCs, laptops, and even most palmtop systems.
Hope this helps you out,
Ken
SOURCE: LCD furuno GP31
Even Im facing the same problem, when I gave it for repairs, they says that the screen is moulded with Body, hence it cannot be repaired.
SOURCE: radar install problem
the GP31 has an NMEA in/out in the power cord - out is yellow green in blue(or black) and white on the 1833 you will use data 4 typically which has an in and out also, same colors hook out to in and in to out, program and done
SOURCE: What do I do to download my GPS Furuno GP31 to my
Go to www.furunousa.com and download the installation manual
I have posted the Operator Manual at
http://www.offscotland.plus.com/Temp/GP30-GP35-Operator's_Manual.pdf
Use this to check out section 7-10 to make up a cable to connect to a PC to allow download of data. Then, using the manual as a reference figure out the sequence of buttons to press to get the GP31 to download the waypoint and route data to the PC. Just press the buttons and assume the display is showing the next prompt. If you know someone you has a working GP31 get them to do the sequence and write down the buttons they press. You just copy the same sequence. You will need some software on the PC to capture the data,
Is this a request for a GP31 Manual? I have posted
http://www.offscotland.plus.com/Temp/GP30-GP35-Operator's_Manual.pdf which is basically the same beast.
http://www.offscotland.plus.com/Temp/GP30-GP35-Operator's_Manual.pdf The GP30/GP31/GP32/GP35 are all similar.
