The metal part for lens mount on the camera body is shaky, and when I mount the lens it still moveable on the even if it looks fitted exactly on its place.
Remove front cover (four screws, one front, two sides, and one bottom), plus loosen two screws holding door latch plate and lift plate up slightly so front cover will lift free (plate has tabs that fit in slots in front cover. Do not lift up too high, just enough to slide cover free). Tighten four metal mount screws and re-attach front cover
Testimonial: "Thanks, was easy and fixed perfectly!"
SOURCE: wide angle/fish eye lens
Hey matty reps,
I found one wide angle lens attachment that should work for your camera and I have attached a link to it so you can see what you think. I have little experience with these types of lens attachments, and have heard they're not nearly as good as having a wide angle/fisheye lens that mounts directly to the camera. If you don't mind losing autofocus you can usually find very cheap manual focus lens that are very high quality lenses for sale at some local camera shops. I hope this helps!
http://www.sakar.com/p-105.aspx?categoryid=142
Sincerely,
Allan
Go Ahead. Use Us.
SOURCE: lens mount ring
see this:
http://flickr.com/groups/49231982@N00/discuss/72157594578814478/
and then this:
http://www.canonfd.com/ketil/
SOURCE: ordered lens for Canon T70 camera
Hi there and welcome to FixYa.
Check on the box. Your camera has an FD mount. The lens you need to use also has to fit the Canon FD mount. If the lens you received is not an FD mount lens...send it back.
Thanks for coming to FixYa.
Rob
