Keeps throwing up oxc 19a0007 error message
SOURCE: HP printer hp D7163 error:OXC 18a 0205
this is beacuse of 2 reasons
1)printer internal firmware corrupt
2)ink system failure
try this
SOURCE: hp c7180 ink failure
Here is the exact sequence for the C7180. It worked great for me:
This is easily fixed with the following key sequences. You do NOT have to open the printer and unplug a circuit board.
1) press * and # at the same time
2) press 1, 2, 3 and “support R0632M” should display
3) press > and “information menu” should display
4) press > and “configuration menu” should display
5) press OK and “hardware failure status” should display
6) press OK “failure status: clear”. Press OK to clear
7) press CANCEL
8) press CANCEL
9) press CANCEL
10) turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
NOTE: I did this and the fist time the error came back. Do the sequence again (as I did) and the error will be replaced with the usual print cartridge initialization screens. Print a test page to make sure.
SOURCE: I have a c6150 all in one hp with a oxc 18a0206
goes through below link i think it will help you
http://h30434.www3.hp.com/t5/Printer-All-in-One-Software-and/Photosmart-C5180/m-p/130071/message-uid/130071
SOURCE: hp printer error oxc a8a0201
The 'ink system failure' error is caused by air in the ink feed tubes. This happens if you use poorly filled refilled cartridges or you let the cartridge run all the way to empty and the printer sucks air into the system. You will need to purge the air lines to correct the error. We have a step by step guide to do this in an article posted on our services page at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ You should be back up and printing in about 10 minutes.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
