There was an unusual clunk and then noticed that the basket was loose,what is the problem?
SOURCE: washing machine basket tilts to one side when washing
possibly one of the balancing weights, that are held by cables, have dislodged or the cable has come off a pulley. remove covers to look for a faulty condition such as this. I'm not sure of this model's balancing system, but it sounds like this type of problem.
SOURCE: Washer basket has dropped 1.5"
Different models use different devices to "suspend" the tub. Please verify the exact make / model.
SOURCE: I was given a kenmore quei pack 2 washing machine.
best thing to do is put it on a boil wsh with castic soda in no clothes 90degrees wash ok good luck you can buy castic soda from any good diy outlet or even a chemist phamasy
The filter on your pump is probably clogged with lint and
stuff. You have to remove the bottom front panel, 3 torx screws
underneath. The
panel will drop and come off. Drain off the excess water from the hose
you
see. The white filter cover is right in front.
Get yourself a bunch of towels or a good big plastic bag to collect
water.
Unscrew the filter cover and twist the filter out. Clean out all the
stuff and
put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits
of soap and other such things can be
stuck around the inside tub of your washer. Try this product, it works
great on
all front loaders. Use hot water with the Affresh pellet with no clothes
and
run the machine through a cycle. Also
helps with any stagnant water smells. Have you cleaned out your pump
lately. Put the pellet inside the
machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
