Question about Mitsubishi WD-62526 Projection TV
My mitsubishi tv is almost 3 years old and it has no picture but it has sound
Mitsubishi WO-60737 TV 60 inch 180p projection
Posted by Crystal Williams on
Kenneth Lee Sr.
  • 597 Answers
Video board malfunctioning....Get a honest TV tech. Only three years old? It is worth repairing, will deliver several more years of excellent service. A quality television.
Posted on Nov 14, 2013
5 Related Answers
PurplieNicol
SOURCE: mitsubishi model vs-5043
I just had this same exact problem. I looked for an answer on here and could not find one. So I took the back off, vacuumed and cleaned everything out with the hose on my house vacuum, cleaned the bulbs and wiggled them around some. Voila !!!! lights on and all is working fine and better then ever. I hope this helps someone fix their problem. Just saved me tons of money and a morning of hassle.
Posted on May 06, 2008
Anonymous
  • 320 Answers
SOURCE: Mitsubishi screen replacing
You must remove the front bezel and frame holder to replace the screen. You will usually see the screws holding the from from the rear of the unit. Once you get the frame off, take note of the way the old screen is installed. There is usually a label on one side near the bottom; the new screens must be installed with the label in the same location. The lenticular goes on the outside (facing the viewer) and the fresnel goes on the inside facing the mirror. You will be able to recognize the fresnel, it has a series of concentric circles that are raised on the sirface of the plastic Be sure to rate this solution.Thanks!
Posted on Nov 08, 2008
Anonymous
  • 8 Answers
SOURCE: Mitsubishi 80 inch rear projection tv
I will be getting one of these tv's in the next couple of weeks and I will be parting out all of the internal electronics, tubes and lenses. drop me an email. [email protected]
Posted on Feb 28, 2009
Anonymous
SOURCE: Mitsubishi 50 inch projection tv
you probably have a problem with the convergence board.
Posted on Apr 05, 2009
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: My 10 year old 55 inch Mitsubishi rear projection shuts off.
The main board/switch is worn to the point it will not work anymore after a while, I been in the business for years, These are wonderful TV's, yes there are replacement parts but a quick fix your looking for here will be unsuccessful this is the reason I am providing my advice and take a chance on the rating your going to give me. Try www.ebay.com look for people that is saling parts for these TV's.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 03, 2009
Mitsubishi wd-60737 fan problems
i have the same tv i replaced the lamp n now its a oange blinking light on
Feb 27, 2014 | Mitsubishi WD-60737 TV
My tv is stuck in the screensaver mode. I have a mitsubishi 60 inch tv
try the soft restart--turn set on with Mitsubishi remote and enter Menu, 1,2,3, enter.
Aug 27, 2012 | Mitsubishi WD-60737 60 in. HDTV
60 inch mitsubishi comes on no picture only sound and then it will turn off by its self
Most mornons seem to think that your TV is a traditional crt projection when in fact it is a DLP projection set and does not have convergence chips or CRTs. Instead, your set has a DMD chip and a projector lamp that passes light through the light engine where a color wheel is and the DMD chip itself. Often times DLP TVs cycle on and off again when the lamp is starting to go out. Mitsubishi is well known for this. However, it can also be a symptom of the color wheel going bad as well or simply updating the software by downloading it from http://support.mitsubishi-tv.com/
Good luck and rate me when you can.
Nov 30, 2011 | Mitsubishi WD-60737 60 in. HDTV
I have a Mitsubishi WD-60737 60 in. HDTV TV and the picture is blurry at the bottom. What can I do?
If your cables are secure you could have a signal board issue. I would contact the manufacturer.
Oct 24, 2011 | Mitsubishi WD-60737 60 in. HDTV
My mitsubishi Model # WD-60737. It is lesss than a year old. The status light flashs green, the Mitsubishi blue start up page comes up the the tv cuts back off. I have unplug from the wall for an hour....
Tv under a year old call Misubishi for a warrenty repair.Flashes staus light mean could be any these parts have problems power supply board,Ballast board or the pojection lamp itself.
Jan 11, 2011 | Mitsubishi WD-60737 60 in. HDTV
Mitsubishi WD-62526 Projection TV Logo
102 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
