We have cleaned it inside and outside, but the problem keeps happening
SOURCE: GE Freezer Leaking
Open the freezer door, remove the bottom tray, smash the ice on the floor with your fist to remove it. Now get a glass of hot water and pour it into the trough which is at the bottom of the back wall of the freezer. Allow a few minutes for the ice to melt then remove it with an ice pick or scrrewdriver. Once the ice is out, pour more hot water into the trough. Now take a long tube ( an old washer fill hose works perfectly) and stick one end in the hole in the trough. Now fill your mouth with warm water and blow it very hard through the tube. Once the drain is clear, pour some hot water and a very little amount of bleach through the hole.
SOURCE: My GE Profile fridge periodically (eve other n) leaks water
Thaw out the defrost drain in the freezer. It has frozen over and the defrost water has nowhere else to go except on your floor.
SOURCE: My GE Profile wine cooler temp does not respond to any temps
Call GE answer center 1-800-626-2000 ask for tech help,have Model # off data plate ready.
SOURCE: Ice build up on bottom of freezer. Water leaks out.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
SOURCE: 10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
You should follow my exact instructions in order to clean your
wine cooler properly.
1.
Unplug your cooler and remove all
items from it.
2.
Clean the inside surfaces with a mild
cleaner (I recommend you to mix water and soda).
3.
Clean the wire shelves.
4.
Clean the wooden shelves.
5.
Wash the outside of the cooler.
6.
Dry any wet part with a soft cloth.
