Symbol Spectrum24 4131 Access Point (AP-4131-1050-Z2-WW) 802.11b Logo
A
Anonymous Posted on Mar 30, 2013
Reset ap symbol spectrum24 ap 3021 - Symbol Spectrum24 4131 Access Point (AP-4131-1050-Z2-WW) 802.11b
2 Related Answers
Anonymous
  • 52 Answers
  • Posted on Feb 09, 2009
SOURCE: Does the Symbol AP 3021 Access Point accept WPA encryption?
on the info i could find it only supports WEP.
but if your issue is to be more secure look up if it supports a sort of mac filter.
this will only keep everybody out of your router but your signal will only be WEP encrypted.
Anonymous
  • Posted on Apr 23, 2009
SOURCE: Default IP address for symbol spectrum24 ap-4131
Try 10.1.1.1
Reset Access point Cisco 1020
If your current controller can't see the AP, then the 1020 can only be reset through the Controller it was originally configured with. It doesn't have a console port, so you have to connect it to the old controller and run "clear lwapp private-config"
How to reset symbol ws 2000 switch and ap 300
ALL BOX SWITCHES HAVE A LITTLE HOLE ON BACK , YOU CAN USE A PIN TO CLICK IT AND RESET.
1helpful
AP Wireless Network issue with MC9060
TRY TO UPGRADE THE AP FIRMWARE
2answers
How do i connect my symbol ap-5131 to my computer?
exist 2 ways to do it...
first if you now te ip address and the user and password of admin, conect the ap at the ethernet port of you pc and configure it with a ip in the same range that the ap, put the ip direcction in the web browser.
the second way is conect the ap to the serial port and run the hyperterminal if you have windows, maybe you need configure the values of the conecctions.
Reset access point motorola symbol ap 5131
Just pull the power supply plug out for thirty seconds. It works for me. You are correct I don't ever use the reset button. In fact the techs at Verizon told me to just pull the plug out.
Hope this is what you wanted,
Please leave rating...thank you
1helpful
2answers
Manual
Is this a bar code scanner?
If not what piece of equipment is it.
Top Symbol Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
