A
Anonymous Posted on Mar 30, 2013
Sony tc-wr635 won't eject - Sony CASSETTE DECK Single Dual Cassette Deck
37helpful
5answers
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
1helpful
Sony TC-WR690 doors will not open to remove the cassette.
If you remove the cover after unplugging the AC, you will see that when you push the eject button that on the back side the putton is held back by a white plastic piece. Push down the white plastic piece as you press the eject button. The door will open and the tape will release. I jsut did this today on my Sony TC WR 670 dual tape player. Both sides were blocked. I noticed that both fuses on the board were also blown. New fuses didn't solve the problem. May be that the transformer is out?
But received a used sony tc we670 from a dealer who said that the unit was funcitioning. Connected it to my Sony receiver but unfortunately it won't start by pressing in the power button. Any ideas...
I have a TC WR670 and have the same problem. I removed the cover after unplugging the AC. I saw two fuses labelled 1.25 Amps. Both were blown. I got 1.5 amp fuses at Radio Shack and it still doesn't work so must be the transformer?
1helpful
Can't eject cassette
It needs to have a Technician look at it. There can be a few reasons that it is stuck like this.
Sony TC WR565 dual tape deck. Both doors will not
you can not fix it without tearing it apart. if you do take it apart, try to get the front panel off. Hit the eject button and look for a lever that is stuck.
1helpful
Sony TC-WR670 eject wont open deck
I had the same problem. You probably have to replace the rubber belts.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
