Question about LG ELECTRONICS Remote Control AKB73375501 p/n:AKB73375501
How do I get my LG AKB73375501 to interface with my Blu Ray player?
My LG AKB73375501 has stopped interfacing with my Blu Ray player but interfaces with my TV. I can only control my Blu Ray player via my TV remote. The Blu Ray remote used to work but, for some reason unknown to me suddenly stopped. I have tried the suggestion of removing the batteries and depressing the power button but this does not work in this case. The battery connections are fine. The batteries are fine as it still works to switch on my TV or change the AV input but will not control the Blu Ray player - please help. Thank you.
Posted by A Panov Scouse on
  • A Panov Scouse Apr 03, 2013
    Thank you each for taking the time to help. I can confirm that this issue is resolved. LG customer services advised me to remove the batteries from the remote and depress any key for 2 to 5 minutes. I did this and, surprisingly, it worked. Had this not worked they also advised to hold a digital camera in front of the remote and press a button. If a light appears then it works. If no light then it needs replacing. Fortunately I did not need to do this after all. Thanks again.
    Top Expert:
  • LG Master
  • 76,544 Answers
It has to be setup with blu-ray by setup codes. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter."
Posted on Mar 31, 2013
    Thanks Kumar. Please see my reply above. Best wishes.
5 Related Answers
Anonymous
  • 36 Answers
SOURCE: I must be near my
you have a prblem on your t.v maybe sensor is not work
Posted on Sep 07, 2010
Anonymous
SOURCE: My LG remote MKJ40653802 suddenly has the TV
I've the same problem. Have you found a solution?
Posted on Jan 01, 2011
Gale Todd
  • 1116 Answers
SOURCE: trying to find the remote
YOU CAN DOWNLOAD THE DOCUMENTATION FOR THE INNOVAGE (LIVING SOLUTIONS) REMOTE HERE:
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/innovage/jumbo-manual.zip&area=other
Posted on May 29, 2011
Azrael SRL
  • 11800 Answers
SOURCE: We have the LG remote
This remote comes with the LG tv's so it should work without a problem on them - it comes preprogrammed for them. If the remote no longer reacts then it's defective.
All you can do is to take out the batteries, press the power button for 10 seconds to fully reset it then reinsert the batteries, press the tv button and try again. if it fails even after that then take it back to the ones that sold it to you. If it came with a tv then contact a dealer - the remote can't be repaired, it will have to be replaced for free since it's still in the warranty period.
Posted on Aug 15, 2011
gopakumarg43
  • 76544 Answers
SOURCE: LG 52LG50 TV remote stopped working
If the standby light on the TV blinks, as any remote control handset is pressed, means, the circuit between infrared sensor inside the TV and main system control section has the fault. If infrared sensor inside your TV were faulty, this will not happen. Here infrared sensor inside the TV and remote control, are working properly.
the fault is with the main system control circuit itself. To make this more confirm, just replace the infrared sensor inside your TV. It is an easy to get component, and won't cost more too. It can be bought from most of the electronic spare part selling shops at your town. There are so many types of infrared sensors are there in the market. You have to make sure, which type is used in your TV. This part can be located just behind the infrared sensor window at the front panel of the TV. In fact, you have to open the TV to access it, as it will be directly soldered to the front panel control circuit board. For your reference, I hereby includes the images of some types of it. Just see, it is a three solder terminal component, easy to get, and easy to fit. If the fault still occur even after replacing this component, surely the main system control IC and its memory IC section circuit should be troubleshooted. This is really a skilled work.
8_10_2012_9_36_09_am.jpg8_10_2012_9_36_20_am.jpg8_10_2012_9_36_37_am.jpg8_10_2012_9_37_02_am.jpg
Posted on Aug 10, 2012
Bush dvr3006 will play audio disks but wont play any dvd ! just says load for ages then turns off or no disk ! help please ?
These are the formats your DVR will or will not play.
  • Blu Ray Playback: No
  • Blu Ray Recording: No
  • Compact Flash Card: No
  • DTS Decoder: No
  • DVB-C: No
  • DVB-S: No
  • DVB-T: No
  • DVD Audio Playback: No
  • DVD Player / Recorder: DVD Recorder
  • DVD+R Playback: Yes
  • DVD+R Recording: Yes
  • DVD+RW Playback: Yes
  • DVD+RW Recording: Yes
  • DVD-R Playback: Yes
  • DVD-R Recording: Yes
  • DVD-RAM Playback: No
  • DVD-RAM Recording: No
  • DVD-RW Playback: Yes
  • DVD-RW Recording: Yes
  • DVI Interface: No
  • DivX Playback: No
  • Double Layer Recording: No
  • Electronic Program Guide (EPG): No
  • Ethernet: No
  • Firewire IEEE-1394 Interface: No
  • HD-DVD Playback: No
  • HD-DVD Recording: No
  • HDMI Interface: No
  • HDTV: No
  • IPTV (Internet Protocol Television): No
  • Integrated VCR: No
  • MP3 Recording: No
  • MPEG4 Recording: No
  • Memory Stick: No
  • Multimedia Card: No
  • Number of Scart Interfaces: 1
  • PCMCIA Interface: No
  • Progressive Scan: No
  • Real Dolby: AC3
  • Secure Digital Card: No
  • Show View: No
  • Smart Media Card: No
  • Super Audio CD Playback: No
  • Super Video CD / Video CD Playback: No
  • Table / Portable: Table
  • USB Interface: No
  • W-LAN Connection: No
  • xD-Picture Card: N
May 24, 2014 | Televison & Video
My LG AKB73375501 has stopped interfacing with my Blu Ray player but interfaces with my TV. I can only control my Blu Ray player via my TV remote. How do I get my LG AKB73375501 to interface with my
with lg this is normal and there is nothing you can do beside to take the set in for a exchange or repair service- I have an lg device or two that has the same issue, it is the players not the remotes. if i find a solution i will update you good luck questions just ask
Mar 30, 2013 | LG ELECTRONICS Remote Control AKB73375501...
Netflix asks for my E-mail address and password every time. I do not have this problem when I stream to my computer, Before asking for this info, it displays the films I have already seen.
After reading through the specs for your player, it doesn't look like it has a native App for Netflix. It may be using a Blu-ray live interface to get you to Netflix that requires authentication every time.
Sorry :(
Hope this helps.
Jun 26, 2012 | Samsung BD-P1500 Blu-Ray Player
Can i make an internal dvd drive into a dvd player and hook it to a tv
Not directly. The interface from a DVD drive is radically different than the input of any TV. Also, there are no direct control (play, pause, skip, eject, etc.) interfaces from internal DVD drives, either.
The closest you could come is to put the drive in a PC that has TV Out functionality. Such a PC can be built very cheaply, however. Such video cards, most are made by ATI can be purchased on eBay for less than $20.
I hope this helps.
Aug 17, 2009 | Audiovox D1708 Portable DVD Player
No Video on screen at all. Audio comes through ok.
It sounds like the yellow video jack on your dvd player stopped working. Sorry, U have an interface problem. This requires taking it to a shop or a new dvd player.
May 01, 2009 | Televison & Video
When i play my disk in the phillips dvd player the picture comes out blue. I have this problem with all the cd i try to play. Is it because I have a hdmi tv?
HDMI (High Definition Media Interface) is just a specific kind of interface, a connection type and can't really influence color.
No knowing which interface you are using, it's hard to make any suggestions but some connection types can suffer from an impedance mismatch which can cause color problems.
Sit down with your manual for each of these to see which kinds of connections you have that are common to both and try others you have to see if another type can improve the color problem you have.
Feb 28, 2009 | Philips DVP642 DVD Player
LG super blu player won't play blu ray disc
Have you updated the firmware on it? I had a similar problem with a Sony blu-ray player and I had to download an update and burn it on to a CD then allow the CD to update the blu-ray player. What's the model number of your player, I may be able to get a link to the update for you.
Feb 15, 2009 | LG Super Blu BH200 Blu-ray and HD-DVD...
RCA DVD/VHS player-recorder
you gotta call the service number and they will give you a ticket number and an address to send the unit back . They will either fix it or replace with an upgrade. Interface errror means circuit board is bad.
Oct 17, 2008 | RCA DRC8320 DVD Recorder/VCR
Interface error
Throw it away and buy a new one. Less frustration.
Jan 04, 2008 | Sony RDR-VX525 DVD Recorder/VCR
My DVD disc not recognized after loading, how can i fix it? dvd recorder
most of the LG RH177 have such problem...
...so my solutiong is changing the internal drive with the computer DVD-RW(IDE interface)but it need a lot of modification..
.. finally, i able to fit the computer dvd writer into it ....
Nov 18, 2007 | LG RH177 DVD Recorder/HDD Recorder
LG ELECTRONICS Remote Control AKB73375501 p/n:AKB73375501 Logo
306 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
