icons are there but the print alongside is not legible {{{{{]]])))OOOOOcorner symbols at defferent angles tried cleaning but still the same. If I chchanged the memory ram would that help??icons are there but the print alongside is not legible {{{{{]]])))OOOOOcorner symbols at defferent angles tried cleaning but still the same. If I chchanged the memory ram would that help??
You can't post conmments that contain an email address.
If you have Office start a document in Word and open the Insert tab. Click on Symbols and Select Symbol then more Symbols. This opens a dialogue box where you select your font (normal text will do) highlight the @ sign and click Insert at the bottom.
Return to the Word document, resize the @ symbol to suit yourself, copy it and paste it where yo want it.
Go into your email account and change the password. Don't use a single word. Try mixing numbers, letters and symbols in upper and lower case. Also change the security questions.
*Open press F11 while holding down shift and alt (Alt-Shift-F11). to launch the script editor in Word with the file opened *Select the find option (or hit ctl-f), and run a find for the word "password." This should highlight something liket his"32943208"; *Remove the letters and numbers between the tags *Apply the changes made in the document in the script editor and close the window. *On the "Tools" pulldown menu, select "unprotect" Your document should now be unprotected.
In Microsoft Word 2004 Click on Tools in Menu bar Click on Options Under View - You will find Enable/disable highlighted text - Uncheck this and you will find the symbols gone.
If you are using Microsoft word, better you can insert symbols, goto insert then click on symbols from there you can select your choice of symbols. if you don't want to try Microsoft word, then press Function Key.
u may try this..
To unprotect a Word document that has been locked, read on: With the document open press F11 while holding down shift and
alt (Alt-Shift-F11). This should launch the script editor in Word;
Next select the find option (or hit ctl-f), and run a find for
his"32943208";
Delete the letters and numbers between the tags (in the above example this would be the 32943208);
Save the document in the script editor and close the window. You should now be back in your Word document;From the "Tools" pulldown menu, select "unprotect." Your document should now be unprotected....
The Symptoms you get
The script does not execute as you had hoped. Instead you get a WSH message
box.
The Cause of error 800A0408
Your
VBScript contains an illegal character, often at the beginning of a
line. It can happen if you copy the script from word, then paste into
notepad. For example, to 'Rem out a line we need the apostrophe, which
is ASCII character 39; however if you paste from word you may get ASCII
96 (Grave accent). Note the clue Source: Microsoft VBScript compilation error,
this means a syntax error in your script.
The Solutions
Check the punctuation marks in your VBScript, particularly look out for apostrophes
and commas that do not display correctly. The reference to Line: 1 Char 1, means that the very first symbol
that is probably wrong.
