Ovens Logo
Steve Fox Posted on Mar 30, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Belling XOU69MF Tripping breaker after on for 30-40 mins after steam cleaning
Wife steam cleaned oven last week all working fine until then Now after oven heats up approx. 30 mins it trips breaker out opened panels and checked all dry anybody any ideas please
Anonymous
Level 3:
President:
  • Master 949 Answers
  • Posted on Mar 30, 2013
Anonymous
Master
Level 3:
President:
Answers
949
Questions
0
Helped
420806
Points
3655
That's why you use easy off. LOL
If you have run it twice then any moisture should be gone, besides if it was moisture it should trip quick, sounds like a bad element causing the trip. I have never seen a breaker go bad, but they can.
4 Related Answers
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Dec 02, 2009
SOURCE: hi. when we turn our electric fan oven on it cuts
It sounds like the oven element is probably causing the problem, it is more thal likely the element is breaking down as it gets hotter.
My advice would be to replace the element, this is located at the rear of the oven compartment, behind a removeable cover.
This should solve your problem.
Anonymous
  • 1314 Answers
  • Posted on Jan 30, 2008
SOURCE: Wall Oven No Power
yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
johnrodgers1
John Rodgers
  • 80 Answers
  • Posted on Feb 06, 2010
SOURCE: Gas oven - electric igniter - trips electric
you have cleaner inside the glow coil marrets and it is probably causing a short circuit and tripping breaker
Anonymous
  • Posted on Mar 06, 2010
SOURCE: I cleaned the top oven of my WOlf stove and the
did you happen to figure out how to fix this? we have the same problem
Belling XOU69MF manual required
Just set the timer and all willl work. The Famous Forry
Oct 16, 2017 • Ovens
1helpful
Hi,my belling model 664 wh is tripping out just as it reaches set temp on main oven dial,i have just replaced the main oven element, any solutions I would be grateful. Thank you.
Sounds like the amperage draw of the oven is right at the breaker size. Circuit Breakers should not be loaded more than 80%. Breakers take time to trip when they are close to the limit. IF the problem started with the replacement oven element, it may be the wrong one and could be tripping the breaker by drawing too much power.
Otherwise: Wiring or breaker not sized right, maybe another load on the breaker in addition to the oven, possible bad connections causing extra amperage, or wrong the oven element made for a higher amperage oven. In rare cases the breaker might be bad, but this is not likely.
Someone experienced needs to a) identify the breaker size b) verify the wire connected is appropriated sized c) verify the oven's current requirements and d) look for bad connections.
Normally another load would not be on the oven circuit unless a diy person changed the wiring. With those items verified, a clamp on amp meter would be used to verify actual current draw when the oven is on to ensure the load is appropriate for the breaker, wiring and oven. If at this point the load is less than 80% and the breaker still trips, change the breaker.
May 25, 2014 • Ovens
We set our wall oven for self-clean and received an error message after about 4 hours that told us to turn off the circuit breaker. We are unable to turn the circuit breaker back on again.
If you cannot turn the breaker back on then it is no good...some breakers do take some very firm effort to get them to come on...but the oven may have ruined the circuit breaker...
Circuit Breaker Keeps Tripping
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Feb 06, 2010 • Ovens
Hi. when we turn our electric fan oven on it cuts off the electricity, tripping the circuit breaker when it begins to get hot, ie after about 5 mins. Its a belling oven. Any help much appreciated.
2answers
Oven wont work but clock still works
First make sure you didn't trip a breaker. You could have power for the electronics on one side of the 220V and that is why the clock still works. Turn off the breaker and then back on even if it looks on. If it does this again you have a sever problem that will require a service call. If the breaker is tripping it could be other than the oven and if so a new one will work ok unless itsin your wiring.
If this helps you please ratre me accordingly Good luck.
1helpful
2answers
Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
Belling 592SS self clean panels need replacing
Go to:
www.belling.co uk and follow the links
You should find what you are looking for
Fan assisted oven
You could try running a hair dryer or even a heater (like an electrical radiator) in the oven.. BUT be careful.. It's possible you might cause overheating of those items Eg melt something or damage an electrical cord etc. You need to drive the moisture away, so the breaker does not trip. But monitor the process closely, as we don't want a fire. Electricians have a special meter called a megger to test the electrical insulation. We are assuming it's just moisture, not an electrical fault causing the breaker to trip. Most problems like this really need a trained tradesperson to faultfind. Take care please, it can be dangerous.
Whirlpool oven issue
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
