Nikon Coolpix S800c - Digital camera - compact - 16.0 Mpix - 10 x o Logo
Bonnie Posted on Mar 30, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Change to resolution after picture taken
Its on low resolution and I want it higher after the picture has been taken
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Nikon Master 102,366 Answers
  • Posted on Mar 30, 2013
Nikon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428961
Points
622693
Sorry, can't be done. Those pixels weren't recorded, so there's no way to regenerate them.
Think of it this way. Suppose you look out the window and see a red car drive by. Look out the window an hour later and maybe a blue car drives by. Now, how many white cars drove by between those two cars? If you weren't looking (or had a surveillance camera), there's no way to tell. In your picture you've got a red pixel over here and a blue pixel over there. There's no way to tell what was in between.
There are some tricks that can be done to interpolate. If you have a bright red pixel and next to it a dark red pixel, then the pixel between them probably was a medium red. But maybe not: there could have been a blue object in between. Or the pixel in the middle might have been the same color as one of its neighbors. There's just no way to be certain.
Enlarging picture makes them blurry
Digital pictures have a set pixel density (resolution) when they are taken This can be adjusted on some cameras and on others it cannot. IF you are using a camera with a low rating or you have your camera set that way (more detailed picture with higher settings consumes more disk space) then enlarging the picture causes it to become blurry, Check the camera and see what the Mega Pixel rating is. The bigger the number the better and more expensive the camera..
Feb 03, 2017 • Cameras
In uploading to a website, so that pictures could be printed, a comment states low resolution and the pictures may be blurry when printed. Is there any setting on the camera that I can change that would...
I dont know what resolution your camera is, but make sure you have it set at the highest it can go. The higher the resolution the better quality the picture. I had a 12mp camera but you could set it as low as 4mp which is ok for snaps but if you are uploading or printing then you need to set your camera to a higher resolution if you can. Read your instruction book it should tell you how to configure your settings there. If it is an old camera that cant be changed then maybe its time to invest in a higher mp camera perhaps 8mp 10mp or even 12mp
How you change the pic size, when i taka picture, the i get is 160x120, is there a way to get a larger pic...
Cameras on cell phones are low resolution cameras, this means less memory is needed.
To get larger picture, higher resolution picture/images you need to use a digital camera.
1helpful
My pictures are now coming out in low resolution -
You may have accidentally changed the picture quality setting. Go into the menu and change it to a higher setting.
I am getting very low resolution pictures, what should I do? The pictures are very pixelated
So you're having on the resolution problem?
Try this:
1. Turn ON your camera, click center button (OK|FUNC)
2. There will be option for resolution scale.
3. It depends on your camera, higher resolution, higher quality.
Any questions? Feel free to ask me =]
Pictures taken from sony digital camera (6 Mega pixel) are not clearly seen on SONY DVP FX720. Is there any settings we need to do to get good quality?
change the format eg 640 x 480 to a higher resolution ...a good quality uses about 250kb per picture most jpegs use 50kb to save space
a really good picture can use 500kb.
1helpful
Can not change the number of images that can be taken
Ok, this is a very easy procedure..
While in picture taking mode, press the set button and it will activate the controls to choose the image resolution. If you select a higher image size or number, it will improve your quality of picture as the number of the resolution you choose gets higher. Simply use the side scroll and the up/down scroll on the back... that will do it for you!
Resolution
you can't go UP in resolution after taking the pic. You can move it to a PC and lower resolution.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
