SOURCE: Sony KDF-42WE655 Replacement Lamp
First thing i would ask is where is the smell coming from?
SOURCE: Sony Grand WEGA KDF-42WE655 42
See owner / operator manual...if not available,can be downloaded
from our website....................T.
SOURCE: how do you replace a bulb on kdf-42we655 tv
has two knobs right behind the speakers. front panel comes off. dont worry it will feal as if your bracking the panel infront, those are just the way the gromets release. DO NOT USE COMPRESED AIR TO CLEAN!! use vacume rather than blowing dust into optical block. reset the lamp timer after installation. hope that helps.
SOURCE: Spider webs Sony KDF-42WE655
I'm guessing they're inside of the Tv right? well what you could do is buy a can compressed air to remove all the spider webs and dust inside of the Tv :)
SOURCE: I have Sony tv model KDF-42WE655 which stopped
Its not the green light that you should be count but the red. How many times is it blinking? Here is a quick update of the errors that are most common.
3x - Lamp switch not engaged
4x - Fans issue
5x - Lamp
6x - Thermal fuse
