I have lost my remote for my JVC LT-32DA30J i need to retune my tv by using the set top buttons i can enter the menu but cant confirm my selection in the menu? is there are a confirm button available?? ive tried universal remotes(sky and an 8 in 1)' but same problem??? please help : /
Cherwally
    Sergeant:
    Habit-Forming:
  • 156 Answers
I think this might be the right type of remote you need:
Replacement Remote Control for JVC Lt 32da30j
Posted on Feb 04, 2018
1 Related Answer
Anonymous
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
XCAN'T FIND THE BUTTON TO RUN CHANNEL AUTO SCAN
First make sure that the Source is set to TV and a good antenna/coaxial cable is connected to the TV. Use the Input button on the TV (to the left of the power button) or the Input Select button on the remote. Use the up/down arrow keys to navigate through the source list and press Enter to select that choice. (On the TV, the Input button is the Enter button.) Next press the Setup/TV Menu on the remote (or Menu on the right arrow button or Enter. Then go down to Auto Ch Memory and press the right arrow or Enter. With the up/down arrows, navigate to Signal Type and set that to Air (for OTA channels) or Cable with the left/right arrows. Now navigate to Automatic Search and press the right arrow or Enter. Wait for the scan to be completed.
I hope this helps. The steps are shown in the manual for the LT-19D610 on page 18. The manual is available from JVC on the product page: http://support.jvc.com/consumer/product.jsp?modelId=MODL028825 . The direct link to the manual is http://resources.jvc.com/Resources/00/01/47/J55D0221B.pdf .
Dec 05, 2015 | JVC LT-19D610 19" 720p 1366 x 768 35000:1...
Reprogram channels on my Westinghouse tv model sk26h520s for a new location
Make sure that the source is set to TV. If you use the original remote, press the top button between the volume up/down and channel up/down buttons. If you use the buttons on the side of the TV, the Source button is next to the Channel Down button.
Next press Menu. (On the TV, it's the top button. On the remote, it's the top left button next to the arrow keys.) Now navigate down to Channels (use the Channel down on the TV) and press Enter on the remote (or Menu on the TV). Navigate down to Scan Channels and press Enter or Menu (as needed). Choose Antenna or Cable, depending on your source and press Enter again. (Note: the volume buttons on the TV are your left and right arrows in the OSD.) If you get a confirmation notice, select Yes and press Enter.
I hope this helps.
Dec 31, 2014 | Westinghouse Televison & Video
Brought a new jvc LT-32DA30J tv and for two days worked well. However I come home today and turned the tv on and it came up with a message in a box saying "no channels" found. So I tried to retune the tv...
I suggest you read through the instructions again to ensure you are doing everything right and if so return your faulty tv to the supplier.
As a matter of interest, as I have formed the opinion your aerial is an indoor type, if something has happened to the aerial or something else has happened that would stop the signal (digital signals can be fickle) the tv set would seem to be faulty and the supplier/manufacturer won't accept indoor aerial results as a warranty claim (I believe).
You need to test the set with a known good external aerial...
Oct 04, 2017 | Televison & Video
Need code
Hello
You are looking for its service menu code I thinks and posts this solution.
Most JVC sets have the same procedure to enter its service menu.
Press the {MENU} button and go to the User Menu screen, make sure
that the indicator (arrow) is pointed and highlights the "Picture Control".
- The buttons on top of the remote are set to TV & VCR respectively.
- Set sleep timer to "0" minutes and while it is displayed, simultaneously
press the {VIDEO STATUS} & {DISPLAY} buttons.
- The main service menu will be displayed with choices #1 through #9.
- Press one of the corresponding number keys to enter that menu.
- Use the {CH+} {CH-} buttons to navigate within a menu.
- Use the {VOL+} {VOL-} buttons to change the values.
- Use the {MUTING} button to memorize the changed value.
- Use the {BACK} button to exit the service menu.
OK.
Jan 24, 2011 | JVC AV-27D302 27" TV
Have lost all my hd tv stations
Hello
Just reset the TV to factory settings and retune it using auto tuning fuction from the Menu option.
To reset it to factory settings, do the following:
Turn on the TV. While holding down "UP arrow" button on the remote control, press the POWER button on the TV. [The TV will turns itself OFF and then back ON again. Release the "Up Arrow button.
This operation will clear all your customized settings including Paremtial Lock settings.
in otherwords, this is the process to unlock the TV if it is locked.
Retune it by autotune fuction. All the lost stations will emerge again.
Ok.
Jan 20, 2011 | Sony BRAVIA KDL52XBR2 Television
I have a Daewoo DSL22V1WCD combined tv/dvd with built in freeview, our area is in the grasp of the digital switchover - everything I look at says I need to retune the tv - but this tv has various "sources"...
Press the DTV menu button (<<)
Press the Down arrow until you reach Settings
Press OK
Press the Down arrow until you reach Installation
Press OK
Press the Down arrow until you reach First Time Installation
Press OK
Aug 04, 2010 | Daewoo Televison & Video
I have lost the remote and i cant get to tune in the channels, JVC AV-36D303 36" TV
use the button on the actual TV itself, they will do most of what the remote will do, you have menu, left, right, up down, enter./set, ON?OFF. They WILL be there somewhere...
May 02, 2010 | JVC AV-36D303 36" TV
Do I need to retune my LE32R8 having difficulty
Yes.
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
Oct 01, 2009 | Samsung LE37S71 37 in. HD-Ready LCD TV
SAMSUNG LE32R73BDX/XEU TV Digital TV Stuck on bbc1, no access to DTV menu to reset or retune. Sometimes picture is frozen, always it shows BBC banner and Mono. Standby - Info - menu - Mute - Power is not...
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Sep 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
Feb 04, 2009 | JVC LT-32P679 32 in. LCD TV
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
