Question about Samsung SCX 4521F All-In-One Laser Printer
Toner is replaced in samsun scx4521 but toner reset wants password what is it
I had replaced toner but for restting new toner it wants password what is it
Posted by s_4_u1982 on
Adorjani Laszlo
  • Samsung Master
  • 1,316 Answers
Enter in the service mode: Press:
Menu - Copy - Left arrow - Right arrow - Menu - Right arrow
On the screen displayed Tech select Clear data and select Counter clear.
Posted on Mar 30, 2013
1 Related Answer
subbu_kn
SOURCE: I have refilled the toner of samsun scx4300, after
i Have refilled the Samsung SCX-4300 printer Toner recently & i have resetted the Chip also by using the firmware after that Printer is showing scanner error please help me to over come from this issue.
Posted on May 13, 2011
I have forgot my password for Samsun GT-e3309T How do i unlock
here is the hardware reset code
*2767*3855# before this you have remove your memory card and contacts backup. have a good reset
Jan 30, 2015 | Samsung Cell Phones
SCX4521 Printer is displaying error message Scanner Is locked how to solve this problem
Solution from samsung site i hope it will work for you
1. Press MENU # 1 9 3 4 in sequence rapidly. The LCD panel should now display TECH.
2. Press MENU, and then press ENTER. The LCD panel will display Tech Mode.
3. Press the left arrow (4. Press ENTER. The operator panel will display [YES].
5. Press ENTER. The toner warning message should be gone.
6. To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH.
Oct 18, 2010 | Samsung SCX-5530FN All-In-One Laser...
I have refilled the toner of samsun scx4300, after refilling TONER EMPTY, REPLACE TONER message is being displayed, please suggest how to over come the problem
Aug 09, 2010 | Samsung SCX-4300 Monochrome Laser...
I have a samsuns SF515 fax machine after changing the toner cartridge the message still appears "toner Empty" I have tried several new cartridges with the same issue.
if you have changed the drum/toner unit then the machine should have a fuse on top of the drum unit.I have come across some cartridges that don't have them on the unit.The fuse resets the fax so that it knows there is a new unit installed.If that does work then clear the machines memory using the control panel
Jun 14, 2010 | Samsung SF-515 Plain Paper Laser Fax
I forget the privacy password on samsuns u900 can u help me out how to reset privacy password thx
You may have to go to a direct att store and have them put in direct code for it.
Mar 06, 2010 | Samsung U900 Soul Cellular Phone
Waste toner tankFull/uninstalled
That is a problem with the toner sensor, it's in the black window behind the waste toner bottle. Sometimes blowing the toner off with a duster can will help, but usually I have to replace the entire sensor assembly JC96-03234A
Aug 05, 2009 | Samsung CLP-500N Laser Printer
Resting the toner ctridge
you dont say what brand or whether you have used refills before. Some laser toner cartridges have a chip on them that has to be reset.Refilling does not fool the printer i'm afraid. Contact the seller of this brand and check out how to overcome this
Jul 25, 2009 | Office Equipment & Supplies
Brother 2140 toner light keep flashing and i just replace it with new toner
You need to look at the toner cartrage if it was a new or compatible cartrage bought to replace the old one the problem would not exist unless the printer is broken.(Or if the replacement has a missing or broken or miss postioned counting gear.)
Thier is a counting gear on the left side and on new or replacement cartarages it is in the 11 oclock postion when it is new. When the toner is all used it moves to the 3 oclock postion. What you need to do if you refilled the toner from a refill kit is to manually move the gear.
I believe thier is two ways to do this one buy a reset gear tool.
The other way that I do is to remove the three screws carefully that holds all the gears in place. Dont worry as it is just the cover and you can not really break the cartarage unless you strip the screws.
Once opened manually using your hand push firmly on the counting gear until you move it back to the 11 oclock postion. Then carefully reassemble the cover.
Once you place the cartrage back in the light will go off on its own and the toner counter will be reset.
3 don'ts
Do not try to only move the counter without refill you may get a few pages but this is bad for the printer
Do not leave any toner in the cartrage when refilling as this contaminates the toner and really shortens the refill life, try to get all the toner out as possible before refill.
Do not keep reshaking the cartrage and place it back in the printer, everytime you insert the cartarage the it can snag or be inserted a tiny bit wrong and break the gears in the printer. Do so in emergencys only, the rest of the time just refill the toner. $10 with delivery on ebay
Jul 09, 2009 | Brother HL 2140 Laser Printer
Low toner
No what u have is that you need to also replace the Drum. That is why the light is reading low toner still.
Feb 13, 2008 | Brother IntelliFax-2820 Laser Fax
Toner empty error while toner is not empty, cannot print any document, system data can be print through the printer
toner empty replace toner with without reset chip
i want window file printer start without reset chip run printer
i am all ready use ml1640,ml2245 printer file use
thanks
vijay
Dec 04, 2007 | Samsung SCX 4200 All-In-One Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
207 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
