Question about RCA RCR460 Remote Control
CINEVISION DVR1000 REMOTE CODES FOR RCA UNIVERSAL REMOTE RCRNO4GR
5 Related Answers
Anonymous
  • 49 Answers
SOURCE: no usable code for CineVision DVD player with RCR461.. HELP!
A learning remote lets you program it with the original remote. I did it today with a Phillips brand remote I bought at Wal-mart. I have an cheap Memorex TV and when I pressed the volume down button on my Comcast remote, the TV setup menu appeared. I had to "teach" the new Phillips universal remote by pointing it at the original remote that came with my TV and pressing cooresponding buttons on both units. It was a bit of work, but it worked.
I guess this is useless unless you have the remote that came with the unit and don't mind switching to a new remote that has learning capabilities.
Posted on Dec 31, 2008
supernova278
Udhaya Rajan
  • 1932 Answers
SOURCE: Cinevision DVD player work with RCA universal
You dont have codes for cinevision DVD player.So it cannot be programmed with Codes.
You can try programming withot code
Please follow the below steps.If it dont work then your cinevision DVD player donnot support RCR460 remote.
Code Search:
  1. Turn on the device you wish to control.
  2. Press and hold "CODE SEARCH".
  3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
  4. Release "CODE SEARCH".
  5. Press ON/OFF repeatedly until the device turns off. You may have to do this up to 100 times.
  6. When the device shuts off press and release ENTER.
  7. Try using the remote. If it does not function repeat steps 1 through 6.
Thanx
Posted on Jul 25, 2010
gopakumarg43
  • 76416 Answers
SOURCE: need to program rca rcrno4gr remote to my rca tv
Hello
Setup codes for RCA TV with RCA RCRN04GR remote control are:
11547, 11447, 10047, 10093, 10679, 11047, 11147, 11247,
11347, 11781, 11948, 11953, 12002, 12187, 12247, 12434
OK.
Posted on Aug 28, 2011
SOURCE: How to code search RCA universal remote rcrno4gr
  • 1Turn on the component you want to program.
  • 2Press and release the component button on your remote that corresponds to the component you want the remote to operate (TV, VCR, etc.). The illuminated ON-OFF button will turn on and remain on.
  • 3Press both the component and the ON-OFF buttons. The illuminated ON-OFF button will turn off, and then will come back on.
  • 4Release both buttons after the ON-OFF button turns back on. The button should remain illuminated.
  • 5Press and release the PLAY button. If the component does not respond after five seconds, continue to press the PLAY button every five seconds until the component turns off.
  • 6Press and release the REVERSE button when the component turns off, then wait to see if the component turns on again.
  • 7Press and release the STOP button to save the new code
  • Read more: How to Program an RCA Universal Remote Control ' eHow.com http://www.ehow.com/how_9191_program-rca-universal.html#ixzz1dVicIcMK
    Posted on Nov 12, 2011
    camachoroger
    SOURCE: lost code for rca universal remote #rcrno4gr need tv codes
    Need code of rcrno4gr remote for a LG tv
    Posted on Dec 26, 2011
    Need code for Panasonic DVD Recorder DMR-ES25 so i can program RCA RCRNO4GR UNIVERSAL REMOTE. Can you help?
    The applicable code will be in the remote. Use code search IAW directions to find something that will handle some or all functions of your Panasonic DVD recorder. If a search through all codes stored in the remote fails (unlikely), you may have to try a different universal remote. All universal remotes do not contain all possible codes.
    Dec 09, 2016 | Panasonic Televison & Video
    What is universal remote code for bd-2000 on rcrno4gr remote
    Remote code for HP BD-2000 Blu-ray player - AT&T Community
    https://forums.att.com/.../Remote.../Remote-code...BD-2000.../467...
    AT&TDec 2, 2012 - I have an HP BD-2000 Blu-ray player that I recently lost the remotecontrol for. I do not see HP as a manufacturer on the DVD list when I try.
    Universal Remote Control Codes List - TV SAT DVR ...
    removeandreplace.com/2013/11/10/universal-remote-control-codes-list/
    Nov 10, 2013 - We compiled this universal remote programming code list to make it ..... Looking for a code for a orion vcr I have a 5 digit universal remote by rca -rcrn04gr and I ... remote control code (s) for a samsung blu ray dvd player bd-fm51 /ZA ... Please, could someone to give me the code for DENON AVR-X2000.
    Programming the RCA RCRN04GR Universal Remote
    voxrightnow.custhelp.com/.../programming-the-rca-rcrn04gr-universal-r...
    Jul 28, 2010 - Program your Remote. To use this universal remote with your home entertainment system, first you need to program it to control your devices.
    [PDF]Rcrn04gr - Universal Remote Control Codes
    Jan 19, 2016 | HP bd-2000 blu-ray player with 1080p...
    WHAT CODE SHOULD I USE ON MY RCA TV? HAVING TROUBLE PROGRAMMING IT
    If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
    http://electro-medical.blogspot.com/
    http://remotesearch.blogspot.com/
    http://electrohelponline.blogspot.com/
    Sep 14, 2014 | RCA Televison & Video
    I'm trying to find the model number of my cinevision dvr1000 remote
    If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
    Mar 24, 2014 | Hitachi Televison & Video
    What is the universal remote code for RCA DVD?
    UNIVERSAL REMOTE CODE .
    Find all the code you need for your universal remote.
    Universal remote codes DVD Player
    Aiwa = 0641, 1912
    Anam = 1913
    Apex Digital = 0672, 0717, 0755, 0794, 0796, 0797,
    0830, 1100, 1915, 1937
    Audiovox = 0790
    B & K = 0655
    Blaupunkt = 0717
    Blue Parade = 0571
    Broksonic = 0695
    Cambridge Soundworks = 1916
    Cinevision = 0876
    Classic = 1917
    CyberHome = 0816, 1019, 1023, 1024
    DVD2000 = 0521
    Daewoo = 0784, 1918
    Denon = 0490, 0634
    Emerson = 0591
    Enterprise = 0591
    Fisher = 0670, 1919
    GE = 0522, 0815, 0717
    GPX = 0699, 0769
    Go Video = 0715, 0783
    Gradiente = 0651
    Greenhill = 0717
    Harman/Kardon = 0582, 0702
    Hitachi = 0573, 0664
    Hiteker = 0672
    IRT = 0783
    Initial = 1931
    Integra = 0627, 1924
    JBL = 0702, 1926
    JVC = 0558, 0623, 0867, 1901
    KLH = 0717, 0790
    Kenwood = 0490, 0534, 0682
    Konka = 0711, 0719
    Koss = 0651
    Lasonic = 0798
    Magnavox = 0503, 0675, 1914
    Malata = 0782
    Marantz = 0539
    Microsoft = 0522
    Mintek = 0717
    Mitsubishi = 0521
    Nesa = 0717
    Norcent = 0872, 1923
    Onkyo = 0503, 0627, 1924
    Oritron = 0651
    Panasonic = 0490, 0632, 1362, 1490,
    1907, 1908, 1909, 1910
    Philips = 0503, 0539, 0646, 0854, 1914
    Pioneer = 0525, 0571, 0632
    Polk Audio = 0539
    Proscan = 0522
    Qwestar = 0651
    RCA = 0522, 0571, 0717, 0790,
    0822, 1022, 1913
    Rotel = 0623
    Rowa = 0823
    Sampo = 0698
    Samsung = 0573, 0820, 1932
    Sansui = 0695
    Sanyo = 0670, 0695, 0873
    Sharp = 0630
    Sherwood = 0633
    Shinsonic = 0533, 1931
    Sony = 0533, 0864, 1533, 1903, 1904
    Sylvania = 0675, 0821
    Technics = 0490
    Theta Digital = 0571
    Toshiba = 0503, 0695, 1045
    Tredex = 0799
    Urban Concepts = 0503
    Venturer = 0790
    XBox = 0522
    Yamaha = 0490, 0539, 0545
    Zenith = 0503, 0591
    Feb 03, 2012 | RCA Televison & Video
    Need to program rca rcrno4gr remote to my rca tv but lost the codes
    Hello
    OK.
    Aug 28, 2011 | RCA RCRN04GR Remote Control
    Cinevision DVD player work with RCA universal remote?
    Code Search:
    Thanx
    May 07, 2010 | RCA RCR460 Remote Control
    No usable code for CineVision DVD player with RCR461.. HELP!
    Dec 30, 2008 | RCA RCR460 Remote Control
    Remote control device
    you can use a universal remote that allows vcr and DVD operation go to walmart, radioshack, or target
    Jan 15, 2008 | GoVideo Go Video DVD/VCR Combo
    RCA RCR460 Remote Control Logo
    388 people viewed this question
    Top RCA Televison & Video Experts
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
