Question about Avanti Refrigerators
Cicuit board 0757-83835908 - Avanti Refrigerators
    New Friend:
It is a power supply smd 12 volt 6 A model S 126SMD3 it is craft by www.hanny.com.cn
Posted on Jul 18, 2014
  • Keith Thorndyke
    Keith Thorndyke Mar 11, 2017
    How would I order a replacement from Hanny since they have no ecommerce web page?
    New Friend:
THE FOR THIS PEACES NO:0757-83835908
Posted on Dec 25, 2015
I need plans, or electr?nic diaghram(power supply smd 12 volt 6 A model S 126SMD3) to repair it some body can help me
Posted on Feb 07, 2015
6ya staff
SOURCE:
My sony HDR-SR11E`s the touch screen isn`t responding.
My Sony HDR SR-12 had the same problem. The issue is most likely a broken flexible circuit board which runs from the display through the hinge to the main camera body. After seeing the repair costing from $250.00 to $400.00, I determined the camera wasn't worth fixing. Then I found i could buy the circuit board on Ebay for about $30.00. I ordered a circuit board, actually it came with a second board and instructions. It is a fairly tedious repair and took me about 1.5 hours. You need to be fairly mechanically inclined to attempt this repair. Basically you have to disassemble the camera and touch screen, replace the circuit board and reassemble. The cicuir board has to be folded and wrapped around the hinge correctly. I guess the reason they sell two cicuit boards together is to allow you to ruin one on your first try. The boards i ordered had good instructions on how to complete the repair and fold the cicuit boards. I got mine done on th efirst try, so I have another board for when it breaks again. Due to the time required, I can see whay the repair is expensive.
Mar 16, 2014 | Sony HDR-SR12 HDD Camcorder
Looking for schematic drawing for cicuit board for lg 2343tv monitor
go to the website electromaniacs.com you can get free schematic there.
Sep 02, 2012 | LG Computers & Internet
Where do i find the convergence chips on a hitachi 57g500a on the cicuit board? want to check numbers before i order
You tv has two STK392-110 chips and replacement chip number STK394-160E can also be used.
Click on above links to view chip image that will help you to locate in tv circuit board.
Oct 16, 2010 | Televison & Video
No heat. 1 slow blink from circuit board LED.
My thoughts were amateur. Paid a professional to corect the problem.
Jan 12, 2010 | Goodman Heating & Cooling
R60A heater will not come on. Check cicuit board and found 2.7K reistor hot and smoking. Do I need a new circuit board?
Hi, yes I would say you do. I can't give you an answer on what caused this to go out, I do know the board will have to be replaced. I have seen boards with no apparent damage to them be faulty. Replace it and you will be up and running again.
Sincerely,
Shastalaker7
Dec 29, 2009 | Reddy R60A Utility Heater
Our BDW 13 keeps tripping our fuse board
your cicuit is overloaded. hook the DW up to its own cicuit, or at least one that will not overload it. Circuits should not be loaded to more than 80% of their capacity. 15 Amp load no more than 12 amp.
when motors/pumps start they use the most load or power, or when your DW turns on the heat.
Nov 01, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Freezer is working but the refrigerator is warm Parts changed defrost thermostate defrost heater main cicuit board
Try changing the number 1 thermistor (tells circuit board about damper operation ) If still frost , replace # 4 and 5 thermistor .
Aug 05, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Spa will not heat more than 85 degrees or so
on the back of the board is the bottom for seting the max temp follow the intruction from the manual or get one at jandy.com
May 26, 2009 | Jandy Laars Lt 400,000 Btu Heater
Hyper board rebuild tosiba 50h82
there is a place in indiana that rebuilds them pts electronics 1800-844-7871 they are very quick
Dec 28, 2008 | Toshiba 50H82 50" Rear Projection...
Connection of new circuit board to creda tumbe dryer TVR2
Nee
d more info. Need dryer brand, model and serial numbers.
Nov 09, 2007 | Dryers
Refrigerators Logo
5,212 people viewed this question
Top Avanti Refrigerators Experts
Marvin
Marvin
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
