Question about Polder Hardware & Accessories
HH displayed on polder thm-360 thermometer - Polder Hardware & Accessories
1 Related Answer
Anonymous
SOURCE: Polder 891-90 Where can I get
Polder timer manuals appear on following link:
http://www.polder.com/productinfo.html
Typical 891 manual:
http://polder.com.p2.hostingprod.com/images/instructions/891_instructions.pdf
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Aug 28, 2011
Daewoo nofrost multi flow freezer
Sounds like a gas problem if its new under warranty get it replaced.If its old dont repair,replace it.
Sep 04, 2014 | Polder THM560N FridgeFreezer Thermometer...
Can battery be changed on Polder instant read meat thermometer? If so,How?
Batteries can be changed on almost all instant read thermometers
go to POLDER.COM/ support/
then choose then choose
Thermometers
and then enter your model #.
This should take you to a detailed explanation. In general look at the unit and find the place to gently pry the cover apart. remove the batteries and replace with the same new style.
May 04, 2014 | Polder Home
How do you turn off polder digital thermometer
Sounds like the on/off switch is bad. The simplest solution is to remove
the battery to turn it off.
Jun 23, 2012 | Polder Swivel Head Digital Instant Read...
Lost my instruction manual for Polder Digital Therm/Timer/Clock and I can't remember how to set it.
I'm not sure which model number you have.
Polder timer manuals appear on following link: Click on timers and thermometers.
Jul 04, 2011 | Polder Triple Digital Timer Model 891-90
I HAVE LOST MY POLDER THM-360 MANUAL. I CAN'T SEEM TO CHANGE THE TEMPERATURE. I PUSH THE +/- AND IT DOES NOT CHANGE. WHAT AM I DOING WRONG?
here's link to POLDER THM-360 MANUAL online.
http://polder.com.p2.hostingprod.com/images/instructions/THM-360_instructions.pdf
Nov 23, 2010 | Microwave Ovens
Polder 891-90 Where can I get an instruction manual for this meat thermometer Thanks
Typical 891 manual:
Oct 31, 2010 | Polder Triple Digital Timer Model 891-90
I have a polder digital thermometer with two probes--but I didn't get instructions with them.. Can I insert the probe in the oven with the meat cooking or use only with the meat out of the oven to test it...
Timer is not identified for certain.
1) Some Polder timers have in-oven thermometer, and others say not to use thermometer inside oven.
2) The 12453 dual-sensor says inside-oven is ok
3) The 894 dual sensor says inside-oven is ok
4) TM360 dual probe says inside-over is ok
Oct 30, 2010 | Polder Triple Digital Timer Model 891-90
Hardware & Accessories Logo
181 people viewed this question
Top Polder Hardware & Accessories Experts
Gene Haynes
Terry
Terry
Attique-ur-Rehman
Attique-ur-Rehman
Are you a Polder Hardware and Accessory Expert? Answer questions, earn points and help others
