Question about General Electric Adora GHDA670N Built-in Dishwasher
Ge quiet power 3 dishwasher symbol 1 h
Where the minutes remaining panel is the dishwasher will not start but just reads 1 h
5 Related Answers
Anonymous
SOURCE: ge quiet power 3 dishwasher
According to the GE repairman who visited, the solution is to close the machine (with the lights flashing). The machine starts and goes through the cycles, which it does rapidly and then all the lights turn off and the machine becomes silent after 1-1/2 to 2 minutes. Then the machine has been reset to normal. During this reseting period nothing happens inside the machine, although you may hear a running sound.
Thus, the solution is to run the machine in this flashing light state for the 1-2 minutes it takes to go raipdly through each cycle and then reset.
I hope this helps.
Posted on Jan 03, 2009
Joe Hogan
  • 10865 Answers
SOURCE: Dishwasher won't start
If your dishwasher doesn't work at all, check these:
Power from the house
Door switch
Wiring
Timer or selector switch
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Posted on May 30, 2009
tbirdfan1
Michael Thomas
  • 3053 Answers
SOURCE: My dishwasher GE profile quiet power II MV832134B
Hello there again
I think we got disconnected in the chat room so i will post the solutions here for you to check ok
The water doesn't drain from the machine If the water doesn't drain from your dishwasher, check these: Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing. Belt If the motor isn't turning or working, the unit won't drain. at all." If the motor hums but doesn't turn, it may need to be replaced.
Posted on Jun 27, 2010
Anonymous
SOURCE: my ge quiet power 3 dishwasher will not start, the
I have the same problem. If I turn the circuit breaker off (for 30 seconds) then turn it back on, the lights will light up, but the controls don't work. After several minutes, the lights go out again.
Posted on Jul 19, 2010
John Riley
  • 441 Answers
SOURCE: GE Dishwasher Quiet Power III Dishwasher leaking
The average life of dishwashers is 7-10 ten years so it might just be dying but try this. If the leak is a small one that seems to always be near the left side of the dishwasher put a cup of white vinager in the upper rack and run the unit on pots & pans or heavy duty. This is caused by a build up of detergent that make the unit oversuds, when the suds turn back into water it leaks out the left front corner. The amount of water is not huge, one towel to clean up. If the leak is larger it could be the pump is leaking and you can order a new one with your model # from marcone.com
Posted on Nov 27, 2010
GE Quiet Power 3 won't start when door is closed.
What is the exact model number? This may be an issue with the cables that connect the door to the power supply.
Apr 06, 2018 | GE Dishwashers
My GE quiet power 1 dishwasher has flashing lights and won't stop cycling, what do i do?
I have had this problem with this dishwasher in my rented apartment occasionally since I moved in. It would usually reset itself if I let it sit a while, but not today. Today all it would do is flash and beep and I finally just unplugged it. I stumbled across this page and read the post by Dyons above and it worked. Close the door, let it grind away and within 2 minutes it will reset itself. Thanks, Dyons!!!
Sep 28, 2011 | GE Dishwashers
Hello ... We have a GE Quiet Power 3 Dishwasher -- only two years old. Dishwasher won't start ...and we are getting an 1h code. What is a 1h code? The manual does not provide any code...
Try unplugging the unit for several minutes if that does not fix the issue you will need to replace the main control board to fix the issue, let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Dishwashers
My ge quiet power 3 dishwasher will not start, the normal wash and dry lights come on initially but then go off. Still will not work. Any ideas?
Jun 29, 2010 | General Electric Adora GHDA670N Built-in...
Screen frozen with 1 hr remaining
unplug it for a few minutes, see it that resets it.
Mar 02, 2010 | GE Dishwashers
GE Profile Built In Dishwsher won't start when you push the start
I turned off the power to the dishwasher for 10 minutes as recommended by a serviceman via the phone and then turned it back on and it reset itself and worked fine.....
Dec 26, 2008 | GE 24 in. Profile PDW7800 Built-in...
GU2500XTPS3 QUIET PARTNER - NO START.
23310532.jpg The dishwasher will not start. The following things have occurred;
1. The Cycle option light is flashing.
The model is GU2500XTPS3
Can anyone please assist if they have seen this problem before?
Oct 22, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Ge quiet power 3 troubleshooting
I have a GE Quietpower 3 dishwasher and let me tell you it is the worst dishwasher, hands down that I have ever owned. It is not quiet and it certainly does not have any power to clean anything. Or so i thought. After reading a few of the posts on this site it dawned on me to check the drainage. I took the whole drain assembly apart. Cleaned all of the gunk out of it. Then went for the drain hose. It was just about a clean as it was brand new. Then i reexamined the drain and found that it did not drain into the Garbage disposal like I am use too. Instead it had to make an immediate 30" climb into a PVC drain that sat just below the underside of the countertop. I rerouted the hose to dump into a bucket and ran the dishwasher. Guess what??? All clean and no residue. I am off to Lowes now to get the clamps and such to drain the dishwasher into the disposal. I still think this dishwasher is the worst I have ever owned and think GE should give that Six Sigma save a few pennies on one DW and the company can save hundred of thousands, at the expense of a customer spending hours on fix-it sites to find out the company cheapened the pump, a rest! However, for all of you that just want to fix your dishwasher, try draining it into the Disposal now before you blow your pump out.
Mar 08, 2008 | Dishwashers
I hope this helps.
Oct 09, 2007 | General Electric Adora GHDA670N Built-in...
General Electric Adora GHDA670N Built-in Dishwasher Logo
23 people viewed this question
Top GE Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Nathan Van Boven
Nathan Van Boven
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
