SOURCE: how to fix transfer belt
To fix this error, you will need to replace the transfer belt and/or reset the transfer belt count on your printer. If you are happy the the print quality of the printer, then you can try to reset the transfer belt count and that will clear the error. Otherwise you need to get a replacement transfer belt and swap it out before resetting the count.
To remove your existing transfer belt, you need to open the front panel, and remove the imaging unit by pulling the green handle. The belt is located above the imaging unit. Pull the belt down to release and then pull it straight out of the machine. Take your new belt and slide the back into the machine and push the front of the belt up to lock in place. Then you need to reset the belt count.
To do this, follow the steps below.
1. Enter Tech Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press OK
6. Enter Password 1934
7. Arrow to Transfer Belt and press OK.
Hope this helps you.
SOURCE: Transfer belt error
Rather than turn printer off, unplug from power source, wait a few minutes and plug back in. It's worked twice for me so far...
SOURCE: I have a Samsung that say Transfer Belt Error
hi guys.. iam Aqeel from pakistan.
i've just solved that stucking problem today and tellining u guys who are facing such problems over thr.
All you need to do are two steps:
1- detach the paper tray and push it back correctly.
2- open front door and remove toner cartridges, on left inner side u may see a light sensor which detects the toner cartridges.. simply clean this section by a small cotton bud. and left side of toner unit thr is a sensor door, behind that door there is also a light sensor bulb, which needs cleaning by a cotton bud.
thats all
i hope this will help u fixing that problem.
bbyee
Hi
I have a utility to reset the consumables errors on this printer, but only if the component is past its lifecount. (60k for transfer belt)
Its called CLP-300_Reset_RLCv04.exe or just RLCV-04.exe (if you can find a copy)
If you need a copy, let me know and I'll find some way to get it to you.
I've used it for transfer belt reset and it works.
SOURCE: How do i fix a transfer belt error on my samsung
take out the imaging unit(imaging unit is where the toners are put and a green OPC is there).
First open the front cover.
then pull the imaging unit.
after that there will be a delicate transfer belt.
