Question about Home
I am not sure if the wallboard can be sanded and then painted
I think you can paint the old wallboard but you should get some advice from an experienced one before doing wallboard painting. You can also have a look at shower enclosures where you can find various bathroom accessories that will make your bathroom more elegant and attractive.
Posted on Jun 15, 2013
SOURCE: adding wall paper border
hi you never mentioned wheather the paint is gloss, emulsion etc?
if its emulsion it should be fine paste the border, draw some guide lines where you want the border to go so when you come to put it on you will know where it has to go, wipe it over with a damp sponge to get the excess paste off it, otherwise when it dries you will see the residue of the paste.
You can get border adhesive which is really good.
Good luck
Kindly
Richie
Posted on Dec 20, 2008
SOURCE: Yellow Spots on Bathroom ceiling/walls after showers
You will have to paint over your new paint with a primer called BIN which will dry in about an hour. Then you can put your color coat on that. Problem solved.
Posted on Dec 05, 2009
SOURCE: There is a part our bathroom ceiling that my
if it's around the fan then mabey the fan exhaust pipe is not connected .If it's in the attic you can go up there and checkbut if it's between floors you will have to pull the fan down from inside and check. It sounds like your celing keeps getting moisture from the underside of the paint
Posted on Apr 13, 2010
SOURCE: I'm having trouble removing my
First off you need to pry off the cap thats facing you (most models). Then there should be a little hole on the side for each one that needs an allen wrench to unscrew off the wall.
Posted on Dec 03, 2010
go to the home depot and they may be able to suggest a fix for this. or another hardware store. good-day !
Posted on Mar 19, 2012
Jan 19, 2016 | Felker FRS-38 Tile, Marble & Granite Rail...
Aug 18, 2014 | Daltile Bathroom Accessories Resin Soap...
Jan 16, 2013 | Drywall
Jan 05, 2013 | Home
Mar 18, 2012 | Moen YB2818 Eva Towel Bar Bathroom...
Mar 10, 2009 | Samsung HCN653W 65" Rear Projection...
Aug 27, 2008 | Dremel 764 04 Pumpkin Carving Kit Includes...
303 people viewed this question
