Question about MyRete WhosHere
The messages is repeating many times on whoshere
When I recieve a message from anybody, it is repeated many many times and I cant find a solution
We don't know how to retrieve out messages from outside the house.
To play back messages remotely, first you'll need to have set up your two-digit security code (PIN). You can download a copy of the manual here which gives all the details. Once you've done that, here's how to use the system:
1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off), press 0 and enter your PIN code within 2 seconds. The answering system announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
3) Enter a command within 15 seconds. Each command thereafter must be entered within 2 seconds. These are the available commands:
  • 0 then 1 Repeat a Message*
  • 0 then 2 Playing incoming Messages
  • 0 then 3 Skipping a Message
  • 0 then 4 Deleting a Message
  • 0 then 5 Stop Operation
  • 0 then 6 Answering System On
  • 0 then 7 Memo Record/Stop**
  • 0 then 8 Greeting Message Record/Stop**
  • 0 then 9 Answer System Off
  • 1 then 0 Help
* For the Repeat a Message function, press 0 then 1 within about four seconds to repeat the previous message, or press 0 then 1 after about four seconds to repeat the current message.
**For the Memo Record and Greeting Message Record function, the first time you enter the corresponding command, it starts the Recording function. If you want to stop the recording, press 0 then 7, 8 or 5.
4) After the command has finished, you hear intermittent beeps indicating that the system is in the command waiting mode. You may enter another command at this time from the chart above.
5) Hang up when you're done.
Jul 05, 2011 | Uniden TRU8885 Digital Answering Machine
Your account has been found in violation of our policies
This sounds like a message you recieved because they believe you violated their terms of use. If you did, there is not anything you can do other than reading the terms and conditions ahead of time. If you did not however, you should contact the company directly to get your problem resolved. I hope this helps and have a nice day!
May 03, 2011 | MyRete WhosHere
How do you set the answering machine or voice mail on this phone?
First make sure the answering machine is on; press the On/Off button to turn it on and off. To set a message to be heard by those calling in: press and hold Skip/Annc. Begin speaking when A shows in the message window. Speak from about 9 inches away from the phone. Messages must be more than 3 seconds and less than 3 minutes long.
Press Prog/Mem and then Skip/Annc to hear the current message. Press and hold Setup until you hear the current setting (Selected announcement is A or Announce Only). Use Skip/Repeat to change the setting. No one will be able to leave a message if Announce Only is on.
After you have held the Setup button, as above, press Setup additional times to set the number of rings before the machine answers and the remote access code among other features.
To set the date and time, press and hold Clock for 1 second. Use the Skip button to advance the current digit; the Repeat button will subtract one from the current value. Press Clock again to advance to the next value to change (day of week, hour, minute, second).
Press Play to hear new messages; press and hold Play to hear all messages. Press Repeat to repeat the current message. Press Repeat twice to hear the last message. Hold Repeat to slow the message playback.
Delete a message by pressing Remove during playback; press Remove twice to delete all messages (if there are no new messages). A blinking F indicates the memory is full and messages must be deleted.
I hope this helps.
(btw additional instructions for the answering system are available at the AT&T website. Direct link: http://telephones.att.com/documents/product_Product/219/UserManual/1982/1855_manual_bkm.pdf which may or may not work.)
Oct 29, 2010 | AT&T 1855 Phone
When trying to write or recieve msgs on skype i get the following: < div class =" service-holder "> < div class =" service "> < div class =" service-repeat "> < div class ="...
it is much better to uninstall the skype and reinstall it, sometimes when there's a new update or a new program it is having conflicts with some programs.
Sep 08, 2010 | Computers & Internet
How to unblock my facebook messages
I cant send any message to other people. I have bloked temporaly.
Aug 07, 2010 | Compaq Computers & Internet
I have a code for my Uniden cordless to get voice mail while away from home. Not sure what else I need beside the code.
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a
remote location (when you are away from home, or from another room using a
handset). Additionally, you can turn on or off your answering system remotely.
Remote access away from home
You can operate your answering system from a remote location using any touchtone
telephone.
off), press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code"
on page 25).
3) The answering system announces the current time and the number of messages
4) Enter a command within 15 seconds, each command there after must be entered
within 2 seconds. You may select a command from the following chart:
**For the Memo Record and Greeting Message Record functions, the first time you
enter the corresponding command, the phone starts recording. If you want to
5) After the command has finished, you hear intermittent beeps indicating that the
Command Function Command Function
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help
Jul 09, 2009 | Uniden Cordless Telephone
Drum will not turn but it is heating up
Pressing 5 Skips introduction, or Skips to next message.
Pressing 6 deletes current message and Skips to next message.
Pressing 7 plays telephone ID of caller if provided
Pressing 8 Repeats previous message, or repeats message
Pressing 9 Pauses or resumes message
Pressing 0 exits the messaging system.
Jan 29, 2009 | Amana NDE2335AY Electric Dryer
Digitor Answering Machine
To change the message hold down the repeat key and record your message. When you stop holding the repeat button your message will be available to listen to., To change the time hold down the time set button while adjusting the hours and minute buttons.
Jun 30, 2008 | Office Equipment & Supplies
MyRete WhosHere Logo
74 people viewed this question
Top MyRete Apps Experts
Marvin
Marvin
Bill Boyd
ray gallant
Are you a MyRete App Expert? Answer questions, earn points and help others
