Computers & Internet Logo
Question about Acer Computers & Internet
How do you download music from your tablet to your acer computer
Has a usb headphone tv and other connections
Posted by laylacampos on
Anonymous
  • Acer Master
  • 32,281 Answers
Connect an USB cable from your tablet to the USB port on your Acer computer.
You may then need to select connect USB connection on the tablet and the computer will then see the tablet as an external storage device. Your computer will allocate the next drive letter for the tablet click on this drive and the music folder on this tablet. then copy the music files from the tablet to your computer.
Posted on Mar 30, 2013
2answers
I have an acer iconia A500 tablet but get no sound coming from the speakers only when headphones are connected how do I get sound back coming from speakers without using headphones
The headphone jack needs to be replaced. Sound gets switched from speakers to headphone there. When the headphone plug is removed from the tablet the connection inside the jack is lost.
2helpful
How would I connect my acer a1 830 to to my tv to watch showbox ... I was told i could use a micro usb to HDMI adapter to do this and cannot figure it out....
No, the A1-830 doesn't support MHL (micro-USB to HDMI). So the micro-USB to HDMI adapter will not work. The tablet's USB port will only support connecting to the charger or a PC's USB port. Here's a list of known MHL devices: http://www.mhlconsortium.org/devices.aspx . The previous model (A1-810) had a micro-HDMI port that could connect to a TV's HDMI port with the appropriate cable. You might be able to use the AllCast app and a Roku or FireTV box. You will need to upgrade to the Premium version for any files longer than 5 minutes.
The other way to mirror content from the Iconia A1-830 would be to transfer it to your computer. Then send the file to the TV via Plex or SmartShare depending on the file and your TV. If you can upgrade the tablet to Android 4.4.2 or higher, then a ChromeCast will let you mirror content directly from the Iconia A1-830. This will require steps that can make the tablet unusable (research rooting an Android device).
I wish that I had better news for you. Unfortunately, even if you have a TV with a USB port, it probably will not access the files on the tablet. (Many only support FAT32 or NTSC file systems.)
Cant get to play music without headphoes
Most modern computers come with internal speakers already installed, especially laptop computers.
These speakers may be sufficient if you are performing typical computer tasks, but when you play computer games, listen to music or watch movies on your computer, you may want louder and more vibrant sound.
You can achieve this by installing external speakers or headphones. These can be connected to your computer through the speaker or USB ports included on your computer.
Plug in the speakers or headphones.
If the speakers or headphones use a stereo plug, insert the plug into the speaker/headphone port normally located on the side or front of your computer.
This port is often color-coded green. If the equipment is connected using USB, locate a free USB port.
Some external speakers will also need to be plugged into a power outlet in the wall or your surge protector.
This may be all you need to do to get the speakers or headphones to work. If they do not, continue to the next step.
Open the audio settings on your computer.
From the Windows Start menu, open the Control Panel. Here you will find audio and sound settings.
Click the heading to see your sound and audio options.
Choose "Manage audio devices" in Windows 7.
Find your Playback device.
In the Playback tab, you can select your speakers and set them as the default for your system.
If you do not see your speakers or headphones, they have not been installed properly. Disconnect and reconnect them to see if it corrects the problem.
Configure your settings.
Select your device from the list and click "Configure" to test your settings.
You can adjust the volume by using the volume slider on your computer's task bar or using external controls on the speakers or headphones.
Install speakers
http://www.liutilities.com/how-to/install-speakers-to-a-computer/
How do you download music from your tablet to your computer
This is how it is generally done.
Connect iPad to computer
You first need to install APPLE ITUNES..
http://www.apple.com/itunes/download/
once its done connect the usb cable to the IPAD FIRST,
then connect the USB cable to the computer.
this will detect the ipad , install the drivers and launch iTunes so you can transfer your music and such.
1helpful
No speech only music when using headphones
The tablet may be having trouble detecting that the headset is plugged in. You could try an app named SoundAbout (search for it in Google Play) to manually route the media audio to the headphones.
1helpful
For the third time - wesite headphone speakers!
Have you tried asking here yet:http://www.koss.com/koss/kossweb.nsf/cs-contact
Steve Sweetleaf
Steve Sweetleaf
shadow
