Precor EFX 546i Elliptical Version 4 Logo
Vince Amalfi Posted on Mar 30, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Efx stuck key - Precor EFX 546i Elliptical Version 4
Sportsmith LLC
Level 3:
  • Precor Master 920 Answers
  • Posted on May 15, 2014
Sportsmith LLC
Precor Master
Level 3:
Answers
920
Questions
0
Helped
514220
Points
111994
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Precor elliptical stuck key
Using the following link, you can find information on troubleshooting the overlay and upper PCA, starting on page 23 of the service manual.
http://www.sportsmith.net/images/product_support%5Cprecor%5CService%20Manuals%5CCommercial%20EFX%5CService%20Manual,%20C546i%20Self%20Powered%20EFX.pdf
Precor elliptical stuck key, display won't stay on, cycles on and off every 5 seconds, but won't continue
If you have a stuck key error, you need to replace the keypad. It will not work otherwise.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Ramp on my precor 456i won't move
Chances are there is a stuck key on the keypad. Normally the only way to correct this issue is by replacing the overlay and keypad. http://www.sportsmith.net/ Use your serial number to find the correct item for your version.
Ramp is stuck
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
This is commonly caused by a bad overlay/keypad. The only solution to resolve this issue is to replace the overlay/keypad.
Please use your model and serial number to find the correct replacement at the following link: Precor Equipment Repair Parts Treadmill Belts Ramp Sleeves SPORTSMITH net
I have a stuck key. How can it be fix?
How do I release a stuck key in the key panel?
Chances are there is a stuck key on the keypad. Normally the only way to correct this issue is by replacing the overlay and keypad. Use your serial number to find the correct item for your version. http://www.sportsmith.net/
Precor EFX 546 05 stuck key
Corrective Action
1helpful
"stuck key" message on efx 546i, will not engage, already replaced batttery
Corrective Action
I get the message error 05 stuck key on my precor efx 546
Corrective Action
Efx 546 in diagnostics mode, flashes 255 and then real position of incline. getting error 42 when first turning machine on.
ok
elevation needs calibration or stuck
open--put elevation manually lowest and turn the unit on and bring the elevation lowest by pressing el down key
put it together clear it and start elevation will come in the starting position clear it and use it 225 is out of range of elevation
also check elevation fuse if it is good and secure
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
