The message that appier in the camera display is can't read the SD card
SOURCE: sd card error on canon powershot s3
I get a memory card error everytime I insert a memory card. They are not locked and I have tried 4 different memory cards and nothing works. How can this problem be fixed?
SOURCE: Canon Power Shot A400 will only work with original Canon SD card
Make sure you are using an SD card and not an SDHC card. The SDHC protocol is newer than your camera, and your camera does not support it. SD cards have capacities up to 2 GB. Your camera should work properly with any SD or MMC card.
SOURCE: How to format an SD card on a Canon SD600 camera
Could be that you have the wrong memory card.
SD600 will only work with the old SD cards, but the SD780 will take the SDHC cards.
SDHC was intended to give 4gb or more of storage, while the old SD started as 16 mb. Different cameras have different limits, but it is always best to assume that the practical limit on an SD card is 2mb. Even if the SD780 will take the SDHC cards, it can be more practical to only carry 2GB SD cards and know that they will fit either camera
SOURCE: Sd card won't upload video- 'unidentified image' is displayed
iPhoto is for still pictures. iMovie is for videos. Use a card reader to download your videos to a folder you create on your desktop. From there, you can import to iMovie or just play them using Quicktime.
Testimonial: "Spot on... problem sorted. It seems iphoto is happy to load short clips but longer vids are too much so quicktime was the solution. thanks :-)"
SOURCE: camera is stating No Card when there is an SD card in camera
camera sd card board is faulty you need to relace new sd card board.
