Question about Symphonic Televison & Video
Problem programing symphonic dvd video remote control na270
Can't program remote control na270 to record future programs
Posted by Earl Simington on
5 Related Answers
pdiggs
SOURCE: remote control not working and need programming code for cable television/universal remote control
remotes.com says oerseas item-not available?
Posted on Feb 24, 2008
Mike Waldron
  • 1019 Answers
SOURCE: Panasonic DVD Recorder DMR-EX77
It sounds as if the actual T/V channel is out of tune.
I,d suggest powering the player On.
Then using channel 8-12 on the T/V to Scan for its frequency.
When you,ve located it to the Player.
Lock the channel, then use the DVD on Channel 8-12.
Mike @ compurepair.
p.s also check the output from DVD To T/V lead has,nt come loose.
Posted on Mar 17, 2008
Anonymous
SOURCE: need to program rca universal remote for symphonic tv model SC313E
the code is 033
Posted on Nov 08, 2008
Anonymous
  • 247 Answers
SOURCE: Programming Remote Control
here is a link to the codes you will need;
http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/comcast_on_demand_remote_manual.pdf
hope this works for you
please give good rating
thanks
tom
Posted on Dec 20, 2008
andy4254
andy williard
  • 226 Answers
SOURCE: Program a remote control
you can only use the original remote control that goes with that Go Video unit. because its a DVD/VCR combo remote there are no universals that will program to work it.
Posted on Dec 29, 2008
How can I program a remote model nb079 to an lg DVD player
Remote Control Programming Codes - DVD ' SkyBest TV
www.skybesttv.com/remote-control-programming-codes-dvd
Remote Control Programming Codes - DVD ... Lenoxx Sound 1938; Lexia 0699; LG0591 0741 0571 0801 1906 0869 1983; Lifetec 0651 0774; Limit 0716 0768 ...
NB079 - YouTube
? 1:45
https://www.youtube.com/watch?v=y7K_avuRXCk
Sep 24, 2012 - Uploaded by ElectronicAdventure
New Funai-Philips-Magnavox-Symphonic-Philco NB079UD DVDRemote Control. This remote was designed ...
Dec 16, 2015 | LG Televison & Video
Samsung DVD Player remote buttons activate Samsung TV settings
To do a reset of the remote control follow the instructions below.
1. Remove the batteries from the remote control.
2. Hold down the Power button for a full minute.
3. Once done, put the new batteries back in and test the remote control. Please power cycle the unit as well by unplugging it from the wall and leaving it of for a couple of minutes. Once done, test the remote control again. To delete the recorded programs, please follow the steps below
1. Press the BD button on the remote control then press Home. This should bring up the home screen.
2. On the Homescreen, choose AllShare Play and press the Enter Button.
3. On AllShare Play, scroll down to Recorded TV and choose ''HDD''.
4. Now the titles of the recorded programs will appear.
5. Press the Tools on the remote control and select ''Delete'' from the side menu.
6. Select the titles to be deleted by highlighting them, then press the Enter button on the remote control.
7. Select ''Delete'' from the side menu then confirm deletion.
To try and resolve this issue, please reset the remote control. To do so, please refer to the instructions below: 1. Remove the batteries from the remote control. 2. Hold down the Power button for a full minute. 3. Once done, put the new batteries back in and test the remote control. Please power cycle the unit as well by unplugging it from the wall and leaving it of for a couple of minutes. Once done, test the remote control again. To delete the recorded programs, please follow the steps below: 1. Press the BD button on the remote control then press Home. This should bring up the home screen. 2. On the Homescreen, choose AllShare Play and press the Enter Button. 3. On AllShare Play, scroll down to Recorded TV and choose ''HDD''. 4. Now the titles of the recorded programs will appear. 5. Press the Tools on the remote control and select ''Delete'' from the side menu. 6. Select the titles to be deleted by highlighting them, then press the Enter button on the remote control. 7. Select ''Delete'' from the side menu then confirm deletion.
Jun 27, 2017 | Samsung LA40A550 40 in. HD-Ready LCD TV
Need to know how to program a RCA univerical remote to a symphonic tv. and the code to the symphonic tv
the code is 171
the programming process can be found here:
http://www.eliztech.com/remotes/rca-howto.php
Nov 25, 2011 | RCA 4-in-1 Universal Remote Control
Need codes for Go.Video remote control
Go video remote for dvd/vcr recorder combo; you program TV by 2 digit codes. press TV power down when TV is powered on; and input 11 for JVC TV, or 03 for GE TV. You can experiment any two digit codes until TV shut down, then you have just finished programing n150b remote. This also work for all LG dvd/vcr combo recorder remote such as 6711RN203A..
Mar 08, 2010 | GoVideo Go Video DVD/VCR Combo
A friend gave ne an old Symphonic TV with its Remote control. Trying to program my TV but the remote has the ''UP'' , ''DOWN'' , ''LEFT'', ''RIGHT'' arrows but NOT a ''SELECT'' button. I do I lock-in the...
u can go 2 buy a universal remote with a handbook 2 tell u how 2 program it lol.b alot easier.that way if u have dvd & vcr...it can b programmed 2 operate it as well as the tv!universal remotes r the best sollution lol.lazier the better lol.
Sep 23, 2009 | Symphonic SC319C 19 in. TV/VCR Combo
Prog Code on RCA311ST for Toshiba DVD Recorder
yes there is a video on you tube how to program a universal remote
Jan 17, 2009 | RCA RCR311S Remote Control
Televison & Video Logo
165 people viewed this question
Top Symphonic Televison & Video Experts
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
