Pull cover off left end of dash to find the fuse card and replace with same rated fuse.also check lighter socket that their are no objects fallen into it.
Hi! The cigarette fuse is somehow interconnected with the radio fuse. If no luck, then i believe that the cigarette lighter needs to be replaced. Hope this helps and have a good one!
Ok just to confirm that you have actually found the fuse? Under the bonnet by the wiper, right at the back of the fuse box - blue 15 Amp, nearest windscreen and to the right, it is well hidden. If that is OK, then I’m amazed that just the pins bent on the lighter body will result in no voltage. I’m assuming that you have used a meter with the ign switch on. If you have the change the cigar lighter, then you will need to take up the panel. From memory, the ash tray needs to be pulled out first...... Try doing a search on a mercedesclub.org.uk, they will have someone willing to help.
