2005 ladies datejust. I have the crown unscrewed and can set the date, but even with the stem pulled out to next, click hands just go with time.
SOURCE: ROLEX QUICK-SET FEATURE
1) un-screw the pin by turning it towards you, until the spring pops it out. 2) pull the pin out to the next notch 3) turn the pin towards you and watch the date change (if the minute hand is moving when you turn the pin, you pulled out too far).
-Mike
www.perfect-timing.biz
SOURCE: Rolex ladies DayJust
No problem pulling it the way out its okey,Wind it the crown until calendar move so the hands move properly.When you going back the crown,push the crown hardly going inside while pushing, wind the crown until you reach the end so its locks properly,because has a thread needs to lock so it will not wind freely,that all Working guy, txt me whatever happen.
SOURCE: Rolex crown problem
i have the same watch, with the same problem, i called rolex, and they told me that only a few odels of rolex watches do this, you should either take it back to the manufacturer,or take it apart and re fix the adjusting peices that work the hands when you try and turn it clock wise.
SOURCE: setting the date on my rolex president day/date watch
if all else fales, you are probably in need of a service.
SOURCE: Rolex oyster perpetual datejust time/date setting instructions
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
