Fujitsu MHW2120BJ-G1 Hard drive 120GB internal 2.5" SATA 7200rpm buffer: 8MB laptop hard drive. 60 d... Logo
ilam Posted on Mar 29, 2013
Hard disk is not boot up after windows screen appears
My hard disk is not boot up after the windows screen appears it standstill on black with mouse pointer. When i install windows it login and works properly after install completed when i restart it it comes black
Anonymous
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Mar 30, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
28
Questions
Helped
5176
Points
88
It seems you computer is not recognising the hard-drive, on boot up, because it doesn't know where to look, i.e. it is booting up to a different drive letter. Have you got more than one drive on the system? If you have you will need to reconfigure the bootup list. Good Luck. George
3 Related Answers
Neciforo Llanto
  • 942 Answers
  • Posted on Jul 27, 2010
SOURCE: Fujitsu Hard drive MHK2060AT not being read. =/
In a simple way the hard drive doesn't need a driver. Maybe the hard drive cable are not connected properly. You need to check the hard drive if is it connected correctly. Try to make also the BIOS and make your hard drive in to first boot.
Anonymous
  • 10406 Answers
  • Posted on Nov 07, 2010
SOURCE: working on a friends laptop,
Are you using the Fujitsu-supplied Windows XP Installation Media, or a "generic" Windows XP CD-ROM?
The "generic" version may be lacking the device-drivers for the SATA disk-drive,
and therefore cannot "find" the disk-drive.
bronk50
Brian Sullivan
  • 27725 Answers
  • Posted on Mar 25, 2011
SOURCE: my laptop is not working
if your computers motherboard is older than 5yrs and does not have 2 gb of ram it will not support windows 7 also since you have removed your hard drive you must have moved the leads attached
one bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
Screen stays black
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Booting issue with intel D865GSA
First remove the hard disk and see whether you have boot error if you have boot error insert the os cd in to drive and boot from the cd if it works fine you have a problem with the hard disk to clear the hard disk problem use a desktop computer and insert the hard disk as slave in the desk top and boot the desktop with the original drive then right click my computer click mange then disk management and find the laptop hard disk the delete all the part ion in the laptop disk then switch off the desk top and insert the hard disk in the laptop and reload the OS
My Computer use windows XP Operation System. hp 540 laptop when I turn on windows, it show black screen with cursor. It cannot continue log to windows. I check in bios cannot detect hard disk. How to solve...
Open your laptop and and fix the hard disk cable.After this start laptop and check the bios if HDD detected then select boot device and select first boot device is Hard disk.Save the setting and restart the window.You are able to open your window. But If Hard disk drive is not detected change data cable,power cable of Hard disk.If hard disk is detected in bios follow upper rules. And if it is not detected again you should walk into Hard disk repairing center and check hard disk there.
2answers
I got this computer off side of road and can't get windows to load it's try's then the screen goes black . here is what happens . I turn it on the screen comes up black it asks what I would like to do ?...
The first screen (start windows normally etc) appears because the computer ahs not shut down normally before. Since you choose to start windows (normally or last known...) and the Windows logo comes up with the loading bar, this means that the computer is starting to boot. Some hardware or software (windows) problem appears and the boot never ends. Possible reasons: motherboard failure or hard disk failure. A good idea is to re-install windows to check the results. Mention that in case of reinstalling the windows, during the procedure choose to reformat the hard disk so it will be checked for errors and reported.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
2answers
I own a Toshibe Satellite L350D-215 running windows 7, when I power on the laptop it brings up the Toshiba welcome screen then loads a screen stating that there is or has been a problem and you have...
Sounds like you need to run the recovery disk
If your have the Recovery Disk put it in and boot from cd/dvd,
[Push "F12" at the Toshiba boot screen to access the Boot Menu]
you will loss all your info,,
to save your info [pic's] you will need to plug your hard drive into a desktop with sata.. and back up you info that way then run the disk
if you dont have the disk you will need to get a new windows 7 dvd or contact toshiba for a new Recovery Disk set,
Some times they put the Recovery on the hard drive but i think you need the disk with this one.
Startup repair won't run
"Unmountable boot volume" this problem is your hard disk partition which is failure to recognize & identify the operating system running on the hard disk. Reformat your hard disk and put another operating system to run again your computer.
1helpful
Hi. Well there are not any reason for this problem to appear. Done nothing regarding disk problem. Anyway when I boot the process stops with the black screen with "Verifying DMI Data...... Boot from...
You are seeing a failure to read your hard drive.
Now you need to troubleshoot that. Your hard drive could have gone bad or you can boot from a system disk (that would be a Windows system disk) and run chkdsk.
If you need help doing that, just ask. I'd be glad to help you further.
My PC will not start properly - when I turn the computer on, I get the Windows XP start-up screen, and then the screen just goes black. I can see the cursor, but when I move the mouse nothing happens. I...
you may try
1) if you reinstall windows xp but it can't boot from xp disk, you may set the cdrom to piority at bios setup screen, still no boot, you need check your cdrom works status
2) if you reinstall windows xp but display no any hard disk appear that means the HD damaged, you need replace a new HD then do again
3) update some devices driver maybe needed, check from control panel--system--device manager, any triangle yellow mark, you can search from website acording the device model name, download and update them.
Cant boot
In your bios you should be able to change your settings for the hdd. Make sure everything in bios matches your hdd & then save changes & reboot. Hopefully that will allow you to enter windows.
Black screen with mouse only
there are several things which might resolve your problem.
attempt to get into safe mode (with f 8 at boot), and check device manager for problem devices.
insert the vista disk and boot, and attempt to "repair" windows, the boot sector particularly. there is usually a "repair" utility on windows disks which allows you to fix problems without completely reinstalling windows.
your computer may be infected by a virus. if you can get into safe mode, try a virus scanner called "avast" if that doesnt work, try "malwarebytes" or "combofix". these can be found by doing a quick google searc, just make sure you download them from reputable sites. you may have to use a seperate comoputer to download the programs.
if you cannot get into safemode, try the same anti-virus software suites, from a different computer, with your hard drive installed in that system as a "secondary" drive. if this is a laptop hard drive, laptop to desktop hard drive adapters can be purchased for around $20.
Top Fujitsu Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
