I have just bought this camera and taken it on holiday and it keeps freezing! I have tried changing batteries and have reset it to default settings but it still keeps freezing. The only way to get it going again is to remove then re insert batteries but it just keeps dying on me. Can someone help so that I can actually take some pictures on my holiday? Cheers
SOURCE: SONY DSC-W100
it can be possible to select reset icon by selecting menu option.
it is not possible to take this type of pictures because at auto flash mode the subject can't be covered witin flash range .therefore picture may underexposed however the forground within flash range may correctly exposed.If we do all this at flash off mode the motion of subject will appear as blurred due to slow shutter speed.
SOURCE: Finepix S9000 won't turn on with fully charged batteries
Hello!
A solotion is to totally discharge the batteries. Totally! You need to connect the batteries to a resistor.( 10 ohms, 5W) and check when the voltage is below 0,5V each. Then you can charge again.
They say that NiMh dont need to be discharged like NiCd but that must be wrong. I can tell you that I bought a Nikon D1X very cheap from a big photo-shop while the batteries didn't stands for more than a few pictures. (The batteries would cost about $600 they said) But I discharged only the batteries(2) and after that I could take hundreds of pictures before recharging.
So: Discharge your NiMh-batteries totally before charging! (Specially new batteries.)
Per-Olof B.Eriksson, Stockholm Sweden
SOURCE: Sony Camera reset to default setting?
I do have a DSCT100 which has the same menu for this model.
You could go to the HOME menu, look for the Settings icon that looks like a briefcase. Inside the settings go to Main Settings 1 and look for Initialize.
You could also reset it by removing battery for a few minutes.
Hope this helps...ü
SOURCE: Need help back to default settings
If you want to take close-up, use Macro function. Button is located at rear and have sign like flower.
Want to restore default settings, go to camera menu and select Initialize, camera will power off and on again and select all default settings.
Let me know if further info required.
