028,017,073,062,064 are the codes to check with Vivo Brand TVs. If you wish to get more details, check this site. Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter."
SOURCE: i lost my manuals to my philips universal remote how do i program it wthoout using the code
I lost my instructions to program my tv with the remote can you help me
SOURCE: Philips Universal Remote PM435S reprogramming
I have the same tv and remote that you do. I went on Philips website and they have instruction manuals and the code lists. You can also press and hold the 'CODE SEARCH' button until the light stays on. Then press 'TV' button. Make sure your TV is on and press Channel Up button until the channel changes on your TV. If you go too far, press the Channel Down button until it changes again. Then press the Mute button to store the code. Good Luck!!
SOURCE: PROGRAMING MY MAGNAVOX UNIVERSAL REMOTE CONTROL
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This
is the user's manual for a Phillips remote control. There is a list of
codes in it. They should be rather universal. There's also instructions
as to how to program it. I believe that there is a way to program it
without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
Press the Channel Up button repeatedly (up to 300 times) until the
device could be controlled changes channel. The red indicator blinks,
then stays lit. If you accidentally overshoot the code required, press
the Channel Down button to backtrack through the library until the
device changes channel. Pressing Channel Up changes direction to
forward again. Press and release the Mute button to install the code.
Hope this helps :)
SOURCE: Need remote code for Vivo 32" HD LCD bought today.
Try all of these. Hope it works out =)044,005,009,056,057,155,156,172
