SOURCE: Changed batteries, zeros are in display but no key response
Perhaps a the connections are dirty (battery connections) or you may have the wrong battery type/model
SOURCE: HP 12c cALCULATOR
It is not calculating because your decimal point and the digit separator (that's the comma which automatically displays for every group of 3 digits) got messed up. To clear, turn the calculator OFF, then press and hold down the dot (that is the decimal point symbol) key while you press the ON key..
t
SOURCE: The keys stick on my HP 12C calculator so that
Try glass cleaner with a paper towel. If that doesn't work you'll have to take it apart and remove the button pad.
SOURCE: HP 12C Platinum: Whenever I try to solve for
Having gone over a month with no response, I assume this is no longer a problem.
SOURCE: I am currently studying for the CFA Level I exam,
Personally, I'd go with the regular, or the Plus, staying away from the Platinum. There's nothing on the calculator or package to distinguish the Plus from the regular, but the Plus uses two coin batteries while the regular uses three button batteries. The Plus is just like the regular, except a LOT faster.
Testimonial: "k_akima was direct, clear and concise. He explained the answer to my question in an understandable manner. Very helpful."
