Messed up CD400 resolution
Hi Molly,
The 72 ppi figure is merely an arbitrary starting point used by most image editing software. I've known others to use 300 as a default, e.g. Paint Shop Pro last time I looked at it. Why it should have changed I can't tell at this point, unless you've changed your software; but it's not important.
The figure is meaningless until you want to *print* your images, and even then it's best to just set print size *without* resampling the image, and let the resolution look after itself until you have a need for very large prints.
To see what your camera is capturing, the essential figure you need to be interested in is the images' *pixel dimensions*; and in the case of the CD400 they should be 2272 x 1704 at the camera's full res. setting. (Actually, "resolution" is an unfortunate term, in its popular usage. Resolution really describes how thinly or densely the same pixel count is mapped over the intended physical output size.)
Changing the print size *without* resampling the image will cause the resolution figure (72, 300 or whatever else it might be) to change inversely with the print dimensions, but will not change the overall pixel dimensions of 2272 x 1704.
I found the answer on a LENOVO site. Thanks anyway.BTW, it is 2.71" by .82" by 6.60".
