Question about Galaxy Radios DX-979 40-Channels Base CB Radio
Power drops on galaxy dx 959 when switched from ssb to am and back
Mike Charette
    Genius:
  • Galaxy Radios Master
  • 1,847 Answers
If you mean that the power drops from ssb to am then when you change it back what you should do is check to see what power you have to begin with.you may have to go inside the radio to adjust the power. there is hi power and Low power so watch yourself.
Posted on Aug 09, 2014
5 Related Answers
localwonder
Michael Masters
  • 6784 Answers
SOURCE: how can i boost my galaxy dx 959
You will have to take this radio to a tune and peak shop for this upgrade. most audio store tech can do this upgrade or, just locate a truck stop near your location and im sure there is a radio guy on the premises that will assist in this upgrade as well. great radio by the way:)
Posted on Jan 28, 2009
Anonymous
  • 40 Answers
SOURCE: Galaxy DX 959
1. Remove bottom cover from radio. 2. On the main PCB, locate J33. (See diagram above) 3. Locate wires on pins marked "P5" (yellow) & "P6" (grey). 4. Cut wire on "P5" (yellow) and install a SPST switch in line. 5. Cut wire on "P6" (grey) and install a SPST switch in line. NOTE: By using two of the function switches available on the radio will eliminate the need for two new switches to be installed and mounted.
Posted on Mar 11, 2009
Don Reiman
  • 773 Answers
SOURCE: refurbished dx 959 from galaxy no modulation? no transmitt?
If there is no transmit at all, it sounds like it wasn't fully refurbished. If it is just low modulation then just turn VR16 and VR14 all the way to the left.
If its not working at all, send it back. It hasn't been refurbished.
Posted on May 03, 2009
Anonymous
  • 22 Answers
SOURCE: i have a galaxy dx 959 it keys up has no soundor receive
Try a different mic, they CAN cause no sound (receive), and no talking. If that isn't the issue, I'd go to my coax cable, even though they don't look broken doesn't mean that they aren't. I've seen quite a few brand new ones that are bad right out of the box. If all of that checks out I'd grab an SWR/power meter and do a check to see if the radio was registering on the inline meter. I'd say use the one on the radio, but I'd like to see it on the inline so you can really tell whats going on with the radio. I think I'd also get a spare radio, or a friends, and put it in my vehicle and see if it gets out. That would be the best way to check your coax and antenna setup. Aside from that, which is just simple cb logic, I'd say you may possibly have to bring the radio to a tech and have them check it out. I have a DX-959 and a DX-99V and I gotta say, knock on wood, no issues with either one. I really hoped that helped and let me know how things turn out. Its always good to hear from people after they figure out what was wrong, that way we all learn...
Posted on May 14, 2009
Shawn
  • 112 Answers
SOURCE: I have a Galaxy 959 cb radio. I have extended the
its normal its only cause your useung more power from the deck
Posted on Jul 09, 2009
SWR high on SSB
reset your swr on am then go to ssb and set it there.Keep going back and forth until your swr is set.
Jan 22, 2014 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy dx 959not getting out far
MAKE SURE ALL CONTROLS ARE SET RIGHT MODULATION FULLY TO RIGHT CLOCKWISE, R-F GAIN FULLY RIGHT CLOCKWISE. TRY TO GET YOUR MATCH A LITTLE BETTER
Feb 23, 2013 | Galaxy Radios DX 959 SSB CB Radio
Galaxy melaka ssb receives but wont transmit whats the fix
look for other fingers that have been in the radio. then back track from there. It could be a switching diode thats burnt.
Jan 27, 2013 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy 959 oscillating
keep your hands out of the radio . now take it to a tech and have him fix it.
Sep 28, 2012 | Galaxy Radios DX 959 SSB CB Radio
Galaxy 959 wire mic for road king 56
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Jun 20, 2012 | Galaxy Radios DX 959 SSB CB Radio
Galaxy DX 959. SSB doesn't seem to work. The power meter needle moves in AM but not in SSB. I tried adjusting the bias between test points 7 & 9 to 50 mA via VR12, but can only get it down to 90...
on ssyou are some what familiar with working on radio's. just make sure before you pull your hair out aligning the radio that you made sure it definitely is not tx on ssb. b the.Mic gain will increase the modulation. it could just be a meter issue. confirm this by having some one on another radio on ssb the same channel listen for you. if he cannot hear you then the ssb is blown out.sounds likelike
Jun 19, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
Receive is ok, but when I transmit on SSB the Freq. jumps 10KC. What adjustments can I do to get the transmit back on Freq. without effecting the Receive?
go to you tube and type in your radio make and model and watch the review on that radio there is a freq adjustment pod for ssb adjustment. they might tell you if not take it to a radio tech and he should be able to alighn it. there is more than one pod for ssb transmitt and receive.
Mar 21, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
How to adjust frequency on transmit??? Galaxy
hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods DX 2527 - VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC 2....10.240. DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR 6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR 9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power, VR601..13.8 Volt Power Supply. DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240. DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias, VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low Power. DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power, VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for DX 77HML only. DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power, VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power (DX 33HML only)
Unmarked VR in C139..Med Power AM modulation (DX 33HML only) DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low Power, VC1....10.240. DX 2517 and DX 2527-
Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power 2SB817 100 Watt 12A. Derating of this component will cool operation, provide better voltage stability,decrease wobble, allow voltage increase to 14.5 volts comfortably. (replace 10 volt caps in this section of the radio to a minimum of 16 volts before increasing supply voltage to this level)and provide faster swing rise time, Replace Q37 2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and volume of the modulation and it will also run a lot cooler.
Nov 12, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
Off freq on ssb TX.
.002 Mhz is really not that much off, try having them tune to your signal When I talked SSB I would have everybody tune to my signal.
Jun 09, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy Radios DX-979 40-Channels Base CB Radio Logo
110 people viewed this question
Top Galaxy Radios Radio Communications Experts
Edward Stotts
Edward Stotts
Level 1 Expert
Marvin
Marvin
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
