SOURCE: can't get GE profile cooktop clean
Don't buy one is a good start unless you like to spend a few hours everyday attempting to make it look clean. If you are OC you'll love the cooktop BTW. Crappy engineering and source selection. Include it in the price when you move.
SOURCE: Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
SOURCE: GE Profile JGP636 gas cooktop
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
SOURCE: GE Profile cooktop JP360.
Hi marilynmcdon,
You can do it yourself. These cook tops are not glued to the granite at all (Or is not supposed to be). Simply lift is up slowly, start from the side, and lift it slowly. If done carefully you won't damage anything.
Hope this helps
JEDEMEYER1
* If this solution helped you, please rate it.
Testimonial: "There was caulking around the edges but after reading your advice I removed it and was able to gently pry the cooktop off. Thanks."
