Question about Nortel IP Phone 2002 NTDU91BD70E6
How to change the TN number for Nortel ntdu91
HOW TO CHANGE THE TN NUMBER
4 Related Answers
ynotphone
ynotphone
  • 192 Answers
SOURCE: change extension number on Nortel T7316E model
Well ~ eagleeigh731 has it mostly correct, do what he said to do and get into the programming --> find SYSTEM PRGRAMMING --> hit next until you find CHANGE DNs--> OLD DNs (this is the old extn#) 222 then type in NEW DN 431--> then hit the end or release button.
Voila your new extension is now there... to check dial FEATURE 0 then press the intercom button, the new extension should be there.
Posted on Mar 19, 2009
consultel1
george peters
  • 860 Answers
SOURCE: How do we change the phone numbers on the speed dial
Feb 27, 2010- Speed dial numbers 001 -255 (256-279 are personal speed dial entries) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say Terminals&Sets.
The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key 3 times(bottom right arrow).
The display should say Sys speed dial.
Press the show key (top right arrow)
The display should say speed dial#:--
enter in the speed dial number you wish to program.
Press the show key (top right arrow) .
The display should show the existing speed dial number
Press the chg key
Enter in new telephone number
press ok when finished
repeat for remaining speed dials
Press the release key when finished
Posted on Apr 16, 2010
Anonymous
SOURCE: Nortel i2050 doesnt connect for different VISTA users
my i ask you say you are trying to login to the phone why?
when you say you but them on to a new tn did you put both ext back on the same tn
Posted on May 01, 2010
curlycord
  • 277 Answers
SOURCE: How do I set up music (radio from my pc) using headphones on my Nortel Networks phone, model #NTDU91? Is there a feature for that? Thank you
You should call in your local vendor and have this done.
They will need to install a jack that matches your headphone jack and punch it down to a certain pair on the phone system, they will also need to go into configuration programming and set the feature.
Config password and knowledge of wiring and programming required. Note you need to purchase a license to "re-broadcast" music on phone systems, paging equipment etc.
Canada license - http://www.socan.ca/licensees/faq-licensing
USA license - http://www.ascap.com/licensing/
Penalties:
The Penalties
Under U.S.C. TITLE 17, the law allows copyright owners to receive as damages for infringement between $500 and $100,000 for each work infringed
Posted on Nov 06, 2012
CCR keeps enabling on Nortel Norstar
CONTACT NORTEL we have no idea what you are doing .
Dec 11, 2017 | Lands Phones
Penalties:
The Penalties
Nov 06, 2012 | Nortel Lands Phones
How to change the number of rings on calls coming in on the nortel t7318e networks telephone
That will require a programming change for your extension. If you are familiar with programming it is located under the capabilities heading and listed next as Forward NoAnswer - press show twice then next and you can use the CHNG soft key to change the delay before being forwarded.
Oct 01, 2012 | Nortel Networks T7316E Telephone Platinum...
How do I change the number on a speed dial
You can program a memory button with a new number or
feature.
External autodial:
1. Press (Feature), ( * ), (#1).
2. Press a memory button.
3. Dial the external number.
4. Press OK to store the number.
5. Label your new button.
Internal autodial:
1. Press (Feature), ( * ), (#2).
3. Dial the extension number.
How to erase memory buttons:
3. Press OK to erase the button.
Alternatively, you can download the Nortel T7316 Quick Reference Card from IdacomUSA, your solution for Nortel Repair and Refurbishing.
Feb 11, 2010 | NorStar T7316E Corded Phone
Jan 20, 2010 | Nortel i2050
Can I change the number of rings before the night
An AT&T specialist was able to help me over the phone
Nov 05, 2009 | NorStar T7316E Corded Phone
How to get voicemail from another phone nortel 7316e I am trying to get my office messaged from my cell.
If your trying to get your messages from another nortel set in the office press your open voicemail button or feature 981. The left soft key below the screen should say OTHR. press the soft key the screen should change to LOG: enter in the mailbox number followed by the password and #.
If your trying to get your messages remotely, call into the office and when the auto attendant answers, press ** followed by your mailbox number password and #.
Nov 02, 2009 | Nortel T7316E 2-Line Corded Phone
My voicemail on my nortel platinum is locked
You need to reset the password .
Feature 983
enter 1020000 as the password if you have a 3 digit extension number or enter 120000 if you have a 2 digit extension
next press the button under the screen with the heading of m box or mail box
next your options are add delete or change
press change .
next enter mail box number
the next step will be to press the reset button
after re-setting the password press the release button . Now open your mail box and enter the default password 0000
Jun 05, 2009 | Nortel T7316E 2-Line Corded Phone
Nortel Meridian - Admin Password changed & forgotten
Log into the system,
goto>
LD 20
req: prt
type: dn
cust: 0
DN: <the extension number>
press enter till you get req: again
Now write down the TN number.
while in LD 20
req: prt
Type: TN (which you wrote from previous command)
enter till you get a long list
find out a prompt 'SCPW'. The number beside SCPW is the password.
Nov 12, 2008 | Lands Phones
Problem with Nortel WLan handset 2210
must drop the whole programing and start from scratch. it called dumping.
Feb 14, 2008 | Computers & Internet
Nortel IP Phone 2002 NTDU91BD70E6 Logo
134 people viewed this question
Top Nortel Radio Communications Experts
Harrie
MrFixitSTTL
ray gallant
Are you a Nortel Radio Communication Expert? Answer questions, earn points and help others
